Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for Ocean Alexander Click for Abeking
holding tank odors-sour milk!
Discussion in 'Technical Discussion' started by mackenzie, Aug 7, 2006.
  1. mackenzie
    mackenzie New Member
    mackinac island
    Just bought a 70's Chris Commander. Treated both heads with several doses of chemicals. The forward head has never really smelled that bad. The master head, however, has an ongoing odor similar to sour milk!! What can I do to get rid of this once and for all??
    Thanks to all for any imput.
  2. Antonio Torres
    Antonio Torres Member
    Angra dos Reis
    Mackenzie,
    You can use vinegar (a tablespoon) in the head, everytime it smells.
  3. AdmiralMAI
    AdmiralMAI New Member
    Lake Mich
    Try using the enzymes that they put in septic tanks that should quickly deplete whatever the odor causing bacteria find so easy to live on.
  4. dancerscap
    dancerscap New Member
    Hudson, Fl
    Check the shower drain. The shower typically drains into the sump and builds a soap scum that sours and really smells. Sorry, wrong forum, you know that. Anyway, clean the sump and disinfect. Will probably get rid of you odor.
  5. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    Do you have the microphor heads?
    If so, behind the flap that opens to allow the waste to fall in a chamber (which is called the hoper,) can get pretty stinking. Every time you flush, it releases the stored gases and will stink up the whole area. What I do is while flushing the head, holding the flush lever, I take a cleaning brush with soapy solution and really try to get in the hopper and knock off all that old waste on the upper sides that has built up. Just dumping chems in there won't do it.
    If you don't have the microphor heads and you know every thing is as clean as it can be, than you might have to go tank diving for a good cleaning in there. Chems will only do so well and is usually very temporary becuase of the build up on the upper parts were the chems can't reach.
  6. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Mackenzie,
    If it's a lingering odor, and not just when you flush, the hoses could be porous and emitting the odor. Rub the hose and smell your hand (or rag) and if it smells, then change the hoses. It's a ****** job, but changing the hoses should help. Good luck.
    Capt Tom
