Click for JetForums Click for Cross Privacy Matters Click for Burger Click for Nordhavn
Sanitizing an Aluminium yacht
Discussion in 'Technical Discussion' started by keljen, Jul 21, 2006.
  1. keljen
    keljen New Member
    USA, Med,and Caribbean
    Help ! We have a large aluminuin yacht and we have had problems with our gray water pump.
    We have replaced the pump and all is okay , but the interior smells of old wet rags, I wanted to disinfect the bilges with chlorine but have been warned off using chlorine
    "because it will eat the hull ,just like copper does"
    TRUE or FALSE
    Thanks for the help
    Clive MC
  2. Garry Hartshorn
    Garry Hartshorn Senior Member
    Only to a minor degree if the bilges remain wet. if they are really clean and dry then you will have no problem
  3. Dhowdodger
    Dhowdodger New Member
    Arabian Gulf
    Orange flavoured bilge cleaner or diliuted washing up liquid works.
  4. SUPERSOAPER
    SUPERSOAPER New Member
    TAMPA
    Hello,
    I would like to know the same thing.
    I was told that pine cleaner was O.K. to use but I am not sure on that either.
    I used a large amount of dish washing liquid and it helped some but I put a lot of fresh water through each compartment and I then tool all of the water out and dryed it. ( a very big project), even if it doesn't work, it looks very nice and I know more about the boat than I did before I did it.
    PLEASE, If you find out about the bleach, etc. Let me know.
  5. Garry Hartshorn
    You know that is the best way to get to know a boat. And you get to find all the stuff that just is not right.
