Click for Dyna
Click for Crescent
Click for Oceanco
Click for ISA
Click for Westport
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Running Gear Antifoul...?
Reply
Old 03-20-2009, 08:09 AM   #61
K1W1
Senior Member
K1W1's Avatar
I am watching this thread with interest.
I would like to try it out on a new boats props, thrusters and shafts but am not willing to recommend something that seems to be a lot more hype than fact.
I do however rate a recommendation from Ken Bracewell as a pretty positive endorsement.
He wrote about it here: http://www.yachtforums.com/forums/73837-post37.html
Why did it fall off Ken?
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 03-20-2009, 08:17 AM   #62
Capt J
Senior Member
Quote:
Originally Posted by NYCAP123
I was going to add that, but on this I haven't yet seen an apples to apples controlled test yet. What mainly has me wondering on this is that they did have independent studies done, but what they published seemed to be cherry picked (which could have been done just to condense for advertising space). Before recommending a product like this I'd like to know things like: Does the 50,000 sea mile claim stand up in salt water and actual cruising conditions and varying speeds? What would Capt.J's results have been after he "had the bottom soda blasted and applied 5 coats epoxy barrier coating and 2 coats of interlux hard bottom paint", but before adding the sea slide? (Then we'd have an aples to apples comparrison.) Does it inhibit or exaserbate marine growth (If you clean the bottom you need to reapply which means another haul)?
I know my experience with it was not an apples to apples comparision. But, there was no reason for the owner to pay to have the yard launch the boat, then run it for a seatrial, then re-haul it and apply the seaslide. So it is what it is. It did rain after the seaslide was put on and you could run your hand over the bottom paint and it was super super slippery.
The owner is very knowledgable and claims that the speed stayed the same for the entire year and a half before he hauled the boat and repainted and put more seaslide. He has used it on several boats and told me that on a speedboat he gained 5 mph. But he did say that it stays on there for a long time, and it cuts down barnacle growth considerably and the few he has gotten fall right off when you touch them.......
Anyways, this is all I know and it would be interesting to see a better before and after test in the real world. I was hoping Bamboo was going to do a seatrial right after being launched to see how it performs.
Capt J is offline   Reply With Quote
Old 03-20-2009, 08:20 AM   #63
Capt J
Senior Member
Quote:
Originally Posted by FISHTIGUA
Sorry, but I have had issues with Propspeed falling off, maybe I am applying it wrong? I follow what the website tells you to but it peels off after a few weeks.
It's all in the application and prep. The surfaces have to be very clean.
ALSO, electrolyses will make prop speed or any other product on the running gear peel right off. I have had good luck with prop speed, and use it on boats that cruise over 20 knots.
Under 20 knot cruise, I like the tri-lux white and have had good results with it.
Old 03-20-2009, 08:42 AM   #64
Ken Bracewell
Senior Member
Ken Bracewell's Avatar
Quote:
I can't say for certain as I was out of the country when it was actually applied the first time by the shipyard. I had used it on smaller boats with great results so decided to try it on the Curt C (now RENA) back in 2005. When I realized the failure I contacted Prop Speed and they attributed the failure to the application process (could have been the sub-freezing temperatures where it was applied but I honestly can't recall now). Anyhow, they offered to replace the product for free and it has been trouble free for the past 4 cycles (we clean the gear and re-apply every 12-16 months when we do the bottom).
__________________
Never trust a captain who enjoys swimming!
Ken Bracewell is offline   Reply With Quote
Old 03-20-2009, 08:43 AM   #65
Ken Bracewell
Senior Member
Quote:
What is the problem with Prop Speed under 20?
__________________
Old 03-20-2009, 09:31 AM   #66
Capt J
Senior Member
Quote:
There is no problem with prop speed under 20 knots that I know of. It's just that the Tri-Lux is cheaper then the prop speed, and I have had excellent results with it on boats that are under 20 knots. I had tri-lux on a 58' Hatteras YF and it stayed on the props and shafts totally for 14 months and never grew barnacles. After 14 months it started degrading. I also think it is (tri-lux) a more effective at preventing barnacles from growing on the running gear, even though with Prop Speed the barnacles fall off. The problem with Tri-Lux is that over 20 knot cruise , it doesn't stay on very well and starts to peel off and stuff.
Old 03-20-2009, 06:47 PM   #67
CSkipR
Registered User
That is not a very environmentally friendly decision there CSKIPR.
TBT Anti Foulings do harm the environment there is no doubt about it, they are now banned not only in the US but nearly everywhere else.
Ships sailing foreign have to have certificates relating to their anti fouling, it would be shame to apply this and then get sprung on the way back to the US wouldn't it.
K1W1
Your right but worth the risk to me. Its a real problem here. Yachts larger than 90' still have it legally put on in the states.
CSkipR is offline   Reply With Quote
Old 03-20-2009, 06:52 PM   #68
FISHTIGUA
Senior Member
CSkipR,
Is that true on the InterCoastal too?
__________________
Fish happens!
FISHTIGUA is offline   Reply With Quote
Old 03-20-2009, 10:38 PM   #69
CSkipR
Registered User
CSkipR,
Absolutely thats where its the worst problem.
Old 03-20-2009, 10:56 PM   #70
Opcn
Registered User
Opcn's Avatar
CSkipR, well of course its worth it to you, the problem wasn't that economically it didn't make sense to people, its that the costs of people doing it were too high for the community. Ever heard of the tradgedy of the commons or the prisoners dilemma?
Opcn is offline   Reply With Quote
Old 03-20-2009, 11:06 PM   #71
CSkipR
Registered User
Quote:
Yep and your point is
Old 03-20-2009, 11:09 PM   #72
Opcn
Registered User
Opcn's Avatar
My point is that people no longer using TBT isn't a matter of it not being worth it for them.
Old 03-21-2009, 05:17 AM   #73
K1W1
Senior Member
K1W1's Avatar
Quote:
I am afraid that this type of partial compliance with what the rest of the world accepts as being good for the environment is the type of thing that just re inforces peoples opinions about the USA.
The boats over 25m or in some cases 65 ft or made of Aluminium ( that's what I see exempted in most states in the attached article) that have this applied might have trouble when leaving the US to go somewhere else if asked for the Certificate of Coatings compliance on arrival somewhere.
http://www.olemiss.edu/orgs/SGLC/Nat...ntifouling.pdf
__________________
Cheers,
K1W1
Old 03-21-2009, 05:36 PM   #74
Bamboo
Senior Member
Bamboo's Avatar
My boat's bottom is very slippery. The growth at the dock is not greater or lesser than my perceived view of that of the past without the sea slide. I changed my shaft packing in dry dock. I first put in 1/2 inch but that was very very tight- the 3/8 seemed small. I later found 7/16 and this was just right, so I changed all the packing out to 7/16. Lots of wax was extruded. The boat's top speed is no faster than before the sea slide was applied. It cruises about the same at the same rpm. The hull used just under two gallons and "painted" everything except the props by the bottom crew. Went on easily and according to instructions. I have set of 16-92's non DDEC. No load readings and fuel burn is noted at when I refuel. These are my observations on this one boat this one time.
Bamboo is online now   Reply With Quote
Old 04-09-2009, 06:53 AM   #75
CSkipR
Registered User
If you are asking where you can get Hi TBT ( Now illegal in most of the world) anti fouling you are asking the wrong guy.
If you want something that will do the job, try this:
www.yachtpaint.com/Images/15_21868.pdf
You can still get the good stuff in the Bahamas. It is made in St. Pete, Fl. Yachts over 90' can still get the good stuff.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 10:01 PM.
Click for Oceanco
Click for Moonen
Click for Horizon
Click for FLIR
Click for Cheoy Lee
Click for Quantum
