Click for Burger Click for Abeking Click for Glendinning Click for Ocean Alexander Click for JetForums
Gardner 6lxb Diesel Engines
Discussion in 'Technical Discussion' started by david_japp, May 5, 2006.
  1. david_japp
    david_japp Senior Member
    london
    We are fitting 2 totally rebuilt and very beautiful Gardner 6LXBs in my 1961 61ft displacement Van Lent. Does anyone have any experience of these engines and what sort of exhaust system have you ( Apparently they are low pressure engines and it's not a good idea to use a modern aqua-lift type wet exhaust that relies on pressure to blow water out of exhaust)
  2. Garry Hartshorn
    Garry Hartshorn Senior Member
    Many moons ago I worked on a fishing boat with Gardeners which had a dry stack exhausts, but most 50' work boats do. I see no reason not to use a wet exhaust but would probabley avoid an underwater exhaust. There are a couple of companies that specialize in this field and I recomend seeking their advise. Soundown being one of them
  3. Viceroy
    Viceroy Member
    Semi-retired in Sidney, British Columbia
    Gardners
    I agree with Gary. Very conventional for Gardners to be fitted with dry stack and keel cooling in the Pacific Northwest. I'm envious that you've got two of these beauties...you should never be disappointed once they're fully and properly installed. Cheers, Richard.
  4. K1W1
