Click for Westport Click for Nordhavn Click for Burger Click for YF Listing Service Click for Ocean Alexander
Carbon Props?
Discussion in 'Props, Shafts & Seals' started by sabrejocky, Feb 8, 2006.
  1. sabrejocky
    sabrejocky New Member
    Vero Beach, Florida
    Does anyone have experience with carbon-fiber props? are they more efficient? are they more durable, cheaper in the long run?
    Cor
    Take a look at Volante's page. Good info here. It's not hype. A number of yacht builder's have adapted. Many years ago, I conducted extensive research into reflex impeller and stator blades for the Navy. The benefits are numerous...
    http://www.compositecarbonfiberprop.com/
    Beyond the obvious, i.e., replaceable blades, reduced weight, reduced vibration, anti-fouling properties... if the right prop is chosen for load and RPM (and it is properly designed) it will offer performance and efficiency gains. This is a by-product of blade flex, not reduced cross section or less weight.
    There are *true* carbon fiber props. I can't comment on the impact resistance of these props. No experience with 'em.
    Then, there are nylon re-inforced graphite composites that generally offer good impact resistance and increased blade flex. Again, if the right blade thickness, shape, sectioning and durometer are chosen, these props have merit. Their application isn't for every craft. They may be well-suited for yachts, based on the speed and RPM's used in this environment, but they're not the right choice for hi-speed, surfacing apps.
  3. nas130
    nas130 Member
    florida
    Any captains/owners running these props?
    I am curious about real world experience with them, as we are reproping the boat.
    nas
  4. K1W1
  5. mr_sunseeker
    mr_sunseeker New Member
    UK & Med
    Hi I would like to see if anyone has now had experience with carbon props and their remarks?
    Also why are they not suitable for high performance surface use?
    Thanks!
  6. nas130
    nas130 Member
    florida
    I do not know for certain why carbon fiber props cannot be used in surface drives. When surface drives were in their infancy the loading and unloading of the propeller blades caused them to frequently crack. They combated this by using a straight leading edge that is a bit thicker than conventional propellers. I would figure that because carbon fiber blades are even stiffer this repeated stress would cause them to crack as well.
    I nixed the carbon fiber propellers for the last boat I ran based on cost and lack of data. For the price of carbon propellers I could by two sets of conventional props.
    One other thing to consider if you hit bottom and break off all the blades on carbon fiber propellers you will lose propulsion. On conventional propellers it should be harder to completely destroy all of the blades and you will be able to limp home.
    nas
  7. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    I was in a conversation not to long ago with a captain who was telling me that he was running a 120ft boat with carb props. He said it felt like the pitch would staighten out under load or that the pitch was wrong all together. Basically he thought his experience with the props was not very good.
  8. ERTW
    ERTW Member
    North America
    I thought I read somewhere that de-lamination occured on C.F props in highspeed applications from cavitiation...didn't the guys on Earth Racer have this problem and had to replace a prop? Does anyone make them out of S-glass instead?
  9. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    Been a long time since this subject was first brought up,....and then it seems to have died off rather quickly??
    Any new experiences over these last few years??
    I was just looking here:
    ConturĀ® Carbon Fiber Propeller Technology
  10. brian eiland
  11. Capt J
    I've heard that they flex and lose pitch under high load/rpm situations
  12. Nicholasde
    Nicholasde New Member
    San Rafael, CA
    This all very fascinating! great use of materials, Carbon Fiber props better used on smaller crafts?
  13. Laurence
    Laurence Senior Member
    Chattanooga TN
    Prop materials
    Performance Propellers (don't know if they still exist) made sailboat props out of urethane with claims of improved performance under all conditions.
  14. Marmot
    The other side of that scenario is if the carbon props are the type with replaceable blades it is simple and quick to remove the stubs, install new blades in the water at the scene of the embarrassment and continue on with the voyage. No limping required.
