Click for Rybovich
Click for Oceanco
Click for Quantum
Click for Broward
Click for Nautical Structures
Click for Glendinning
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Rim Driven Propellers
Reply
Old 04-23-2006, 04:54 PM   #16
Kyfho
Registered User
Rim thrusters.
These rim thrusters are already in a size and power for integration into mainstream yachting circles. Canyon ROV utilise these on their Schilling Quest electric work class ROV. Alstrom bankrolled the development with their eye on future markets. There were initial teething issues, mainly to do with material/lubrication of the ring bearing and adjacent surfaces, and these have been resolved. Cost is the prohibiting factor at present for the general public. Now that the idea is out there and proven, development by competitors is sure to reduce the cost to a more attainable level.
Regards,
C.
Kyfho is offline   Reply With Quote
Old 04-24-2006, 01:58 PM   #17
YachtForums
Publisher/Administrator
YachtForums's Avatar
Came across a video of a rim-prop thruster being tested...
http://www.compositecarbonfiberprop.com/ring_prop.htm
Old 12-25-2006, 08:55 PM   #18
brian eiland
Senior Member
brian eiland's Avatar
Design of 100kW Permanent Magnet Thruster
Haven't heard much on this subject in quite some time, so I thought I might look thru the internet to see what might be found.
Found this PDF, Design of an Integrated 100kW Permanent Magnet Synchronous Machine in a Prototype Thruster for Ship
"An alternative solution is a rim driven thruster where the shaft and gear has been removed. There are only propeller blades in the water path and only electric cables go through the hull. This improves the efficiency of the propeller, removes the gear and reduces vibration. In this paper the design of an integrated electric machine is presented together with results from the testing of the electric machine. Bearings, hydrodynamics and noise are not discussed"
http://www.elkraft.ntnu.no/eno/Paper...vli-Sandoy.pdf
Can anyone add anything new?
brian eiland is offline   Reply With Quote
Old 04-26-2007, 08:00 AM   #19
brian eiland
Senior Member
RimDrive view
Extracted this view of a rim drive unit from a document recently sent to me
Old 04-26-2007, 12:13 PM   #20
Kruse
Registered User
Kruse's Avatar
nice
I see a lot of potential in these systems:
- The large diameter of the motor will produce a lot of torque.
- Potential for max efficiency with the direct drive (no gearing or gearbox).
- Minimal profile in water, the benefit of ducting (efficiency and build-in rudder function).
- The rim-mounting of the blades (no center hub) should make them much less sensitive to damage.
With somewhat flexible blades (less pressure on the blades in the center),
they could survive chewing on fishing nets, logs, big fish, terrorist divers and pirates etc.
The big question now is longevity, effectiveness, availability, and prize.
Any risk of a galvanic corrosion problem on metal ships with the Carbon/plastic?
__________________
Only 1 man had all his work done by Friday; Robinson Crusoe!
Kruse is offline   Reply With Quote
Old 08-24-2007, 09:52 AM   #21
brian eiland
Senior Member
Another Alternative
Abstract
Rim driven thrusters with structurally integrated brushless PM motors are now an established technology with an increasing range of applications. In these thrusters, the stator of the motor is housed within the thruster duct, and the rotor forms a ring around the tips of the propeller. Such high pole number motors tend to be very thin radialy, have very small length to diameter ratios, and have relatively large airgaps to accommodate corrosion protection layers on the surfaces of the rotor and stator. The relatively large diameter stator laminations of such machines tend therefore to have very thin back of core and narrow teeth, which make them expensive and difficult to manufacture. This paper proposes an alternative potentially lower cost motor topology featuring a slotless stator whose laminations are manufactured from a single strip of steel that is edge wound into a spiral (like a “slinky” and then fitted over the windings that are preformed on the outside surface of a non-conducting former. The former is also part of the sealed housing that protects the stator from corrosion in seawater. The paper discusses the design optimisation of such a motor using analytical and finite element analysis (FEA), describes a demonstrator motor and reports experimental and FEA results.
(had trouble posting rest of article with small file size allowed...will try later to decrease size of file)
Old 09-01-2007, 10:28 PM   #22
Codger
YF Wisdom Dept.
Perhaps someone can clear up a question that keeps coming back for me.
Perimeter driven props being more efficient makes perfect sense to me.
However, having sharp ended blades unconnected in the centre has me scratching my head. Wouldn't there be more flex and therefore loss of efficiency as the blades deformed forwards under load? Wouldn't having them connected in the centre make for one solid structure less prone to flex and fatigue?
Codger is offline   Reply With Quote
Old 09-02-2007, 02:26 AM   #23
First Pericles
Registered User
Exchangeable blades. See Brian's post #19.
First Pericles
First Pericles is offline   Reply With Quote
Old 09-02-2007, 08:15 AM   #24
Codger
YF Wisdom Dept.
The blades shown in post #15 are connected at the centre so it's being done both ways.
Replaceable blades is a nice feature but is there a tradeoff in overall efficiency by not having them connected at the centre?
Old 09-02-2007, 10:25 AM   #25
Castlerock
Senior Member
Castlerock's Avatar
I think that having the added strength of the center hub would reduse blade flex and pitch change. Then again if you could calculate the load and flex you could design in more pitch. Now if someone would make a composite Pod Drive with this system for yachts I can see it being much lighter that the Schottel and ABB units.
__________________
There is no proof that life is serious.
Castlerock is online now   Reply With Quote
Old 04-10-2008, 06:03 PM   #26
brian eiland
Senior Member
Rolls Royce literature
Rolls Royce has posted a few new PDF documents
http://www.rolls-royce.com/marine/do..._rimdriven.pdf
http://www.rolls-royce.com/marine/do.../prop_broc.pdf
Old 04-14-2008, 01:56 PM   #27
Highlander
Registered User
Several advantages
The first thing that popped out is that the blade design can use much less material- less drag. The point of highest velocity/load is at the rim where support is best. The last picture shows a plug connecting the blades- vibration control?
The bearings are interesting too. By using water to generate a hydrodynamic film-the wear component can be less in steady state operation than in start-stop service like a thruster.
The only drawback is the drag caused by the tube/motor.
For commercial displacement use this has lots of promise.
How do you think the drag compares to the IPS design?
Carl
Highlander is offline   Reply With Quote
Old 04-14-2008, 03:46 PM   #28
Dan Evans
Registered User
I hope I am not getting too sidetracked here, but has anyone looked at putting these in a waterjet? I know that installing a waterjet with a rim drive means that the rim drive is now inside the hull so if it leaks its going to be a bad day... The drive is already in a tunnel so I dont see why it wouldnt be easy to adapt to a jet. I think it is a great idea not having a shaft turning in the water but I dont think it is a good idea to have the rim drive mounted under the hull. It is an expensive and probably sensitive piece of equipment.
Dan
Dan Evans is offline   Reply With Quote
Old 04-15-2008, 01:59 PM   #29
Highlander
Registered User
Rim drive jet
Sure it could work and work well.
The downside is that every major component is the most expensive way.
1- jet housing
2- rim drive pod, could be removable from the jet housing for service.
3- Variable frequency drive.
All this stuff works great and has an unknown service life in a marine environment.
Carl
Old 04-15-2008, 04:51 PM   #30
Dan Evans
Registered User
Quote:
...seems to be a common factor in this industry
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 04:31 PM.
Click for Dockwise
Click for Lazzara
Click for Shadow
Click for Trinity
Click For Dockwise
Click for Christensen
