Click for Queenship
Click for Oceanco
Click for Moonen
Click for Heesen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > FUEL TANK NIGHTMARES "ETHANOL IS KILLING TANKS"
Reply
Old 09-13-2005, 08:12 PM   #1
mackenzie
Registered User
IS ANYONE WITH OLDER CHRIS CRAFTS EXPERIENCING FUEL TANK FAILURES/ENGINE FAILURES IN GAS BOATS?? IF YOU HAVEN'T ALREADY HEARD, ETHANOL IS NOW BEING ADDED TO GAS, AND ITS NOT COMPATABLE WITH THE FIBERGLASS RESINS USED IN THE OLD BOATS. IT SEEMS TO BE BOATS OF 1960'S-1970'S, THESE OWNERS ARE ALL CRYING AS THIS IS HAPPENING AT A RAPID RATE ACROSS THE COUNTRY, AND THEY'RE SPENDING THOUSANDS $$$$ TEARING UP DECKS,STATEROOMS, COCKPITS,ETC. IT SEEMS THAT BOAT BUILDERS BACK THEN NEVER EXPECTED GAS COMPANIES TO BE ADDING CORN TO GASOLINE IN THE FUTURE.
I JUST BOUGHT A 1974 42' COMMANDER WITH GAS. I JUST NOW HEARD OF THESE PROBLEMS. ANY IMPUT WOULD BE GREATLY,GREATLY APPRECIATED.
THANKS
mackenzie is offline   Reply With Quote
Old 12-29-2005, 01:48 PM   #2
dogsharks
Registered User
Your Chris should be fine, since it probably has galvanized steel tanks. I'm in Tennessee, but I am in contact with LOTS and LOTS of Chris Craft boaters across the country, and I have not heard of the alcohol issue (yet). Hopefully it's not something that is prevalent in marine gas supply.
Regards,
Dogsharks
dogsharks is offline   Reply With Quote
Old 01-04-2006, 12:28 PM   #3
dogsharks
Registered User
One thing I'd like to add.........the "manner" in which aluminum is used plays a big part in how long a tank will last. There are many grades of aluminum, many dimensions, and many techniques, some of which give aluminum a bad name.
Dogsharks
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 11:49 AM.
Click for Horizon
Click For Affinity
Click for Quantum
Click for MCC
Click for Platinum
Click for Westport
