Click for Nordhavn Click for Westport Click for Delta Click for Abeking Click for Abeking
Largest diesel engine in the world!
Discussion in 'Technical Discussion' started by YachtForums, Jan 9, 2004.
    Largest diesel engine in the world...
    Check out this link...
    http://www.bath.ac.uk/~ccsshb/12cyl/
    Some facts on the 14 cylinder version:
    Total engine weight: 2300 tons
    (The crankshaft alone weighs 300 tons.)
    Length: 89 feet
    Height: 44 feet
    Maximum power: 108,920 hp at 102 rpm
    Maximum torque: 5,608,312 lb/ft at 102rpm
    This is the crankshaft...
    This is the piston and connecting rod...
  3. YachtForums
    These are the cylinders...
  4. YachtForums
    To the top...
  5. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    I bet that would make my 42 Post go a little faster
  6. John B
    John B Senior Member
    New York
    This isn't an engine for a ship. It's really the power plant for a robot to stop Godzilla before he attacks Tokyo again.
    Why else would you need 5 million ft/lbs of torque!
    That thing is insane. I love the ladders integrated into the block to climb down into the crankcase. What kind of warranty does it come with?
  7. JHA
    JHA Senior Member
    fuel economy??
    With petrol prices on the rise I must ask... how many gallons to the mile? I can't imagine the injectors on that beast...
  8. fish
    fish New Member
    St. Pete Bch, FL
    :D :D :D
  9. chrismlewis
    chrismlewis New Member
    Ft lauderdale
    Fuel economy
    A VLCC (very large crude carrier) that I worked on in the distant past burnt 150 tonnes of fuel per day at an operating speed of 14 kts (around 135 US Gal/ mile very roughly). We had a fuel capacity of 10,000 tonnes I think! She was around 300,000 dwt and a draft of 72'.
    I sure enjoy driving yachts!! :D :D
  10. Henrik
    Henrik New Member
    Hamburg / Germany
    around 15 years ago (from 1986 to 1990) i worked as a sailor on containerships at Hapag Lloyd.
    on "Frankfurt Express" (297m) we burned at 24knots around 200tons of fuel every day. but it was a twin screw vessel with 2 smaller engines, each with 9 cylinder and 35.000 HP
    on "Hamburg Express" (297m) we have had a steam-turbine which also had burned around 180 tons of fuel every day at around 24knots on a single propeller.
    but this ship was first build in the 1970's as a 2 screw (and 2 turbine) and has burned with this configuration around 400 tons a day with 29knots every day.
    they changed this 2 turbine configuration in the beginning of the 1980's ... because the fuel was getting more expensive.
    but it was great on that ship, because we had no vibration in the ship.... and on deck no sound.... it was like sailing with 24knots :D
    on the other side, the bad thing was going through the red sea... the temperature in the engine room was at around 65° Celsius ... :eek: , not a nice place to work on.
  11. archnav.de
    archnav.de Senior Member
    Frankfurt Express
    Here are some more Information about the Frankfurt Express:
    Frankfurt Express built by HDW
    Yard No.168, Owner:Hapag-Lloyd, Port: Hamburg, Country: Germany
    Delivery 1981
    TEU 3.045 TEU
    Measuring 58.385 BRT
    Power 2*20.000 kW
    Length 271,00 m (Lpp)
    Width 32,20 m
    Height 24,00 m
