Click for Ocean Alexander Click for Nordhavn Click for Walker Click for Burger Click for Cross
Do you need a stern tube?
Discussion in 'Technical Discussion' started by C4ENG, Aug 10, 2014.
  1. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    This is a picture of a 164ft Trinity stern tube. The stern tube lost its protective epoxy cover inside and might need to be replaced. Some people say that the stern tube is not necessary and can be removed completely.
    Why would the builder then install stern tubes if they are not necessary?
    Could the spinning of the shaft in that tight quadrant create cavitation up against the haul?
    If the builder put it there, it was most likely for additional shaft support and to stabilize the shaft. I would leave it personally unless you have a good naval architect willing to say otherwise. It is possibly it's not getting good water flow to cool it due to the proximity to the hull. However, how many hours are on it? Cutlass bearings only last so long.
  3. captholli
    captholli Senior Member
    In The Bilge
    Let the fun begin!! What does the class surveyor have to say?
    Who would tell you that you don't need what was approved by ABS and built to classification standards by the builder? The guy that runs the travel lift or some idiot captain trying to save himself from the owner/ Management companies **** list?
  4. K1W1
    Get the surveyors opinion.
    If it is badly corroded and corrosion can often look a lot worse than it actually is it is entirely possible that it could be filled with Belzona or similar as it is only the area where the bearings are located that needs to be really true and these could be line bored if so needed.
    It is entirely possible to have a shaft line without a Stern Tube but you will need some other way to secure the shaft bearings to the hull.
