Click for Mulder Click for JetForums Click for Abeking Click for Glendinning Click for Furuno
Aluminum hull bow thruster easier or harder?
Discussion in 'Technical Discussion' started by Danvilletim, May 18, 2014.
  1. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    Aluminum hull bow thruster easier or harder than fiberglass? (62' striker)
    Anything to watch out for?
  2. ArielM
    ArielM Senior Member
    Los Angeles
    the big issue with this i would think is welding on 20-30 year old aluminum that has been submerged in salt water all these years. Aluminum should be very clean anytime welding is done. Not that it can't be welded, but i would assume it makes it harder. still faster then glass though...
  3. Danvilletim
    isleton, ca
    Older aluminum less weld able? Audio gauge came out with no noticeable loss.
  4. dsharp
    dsharp Senior Member
    lake jackson, tx
    Aluminum gets a build up on the surface that has to be removed to a shiny surface before it can be welded. It also tends to crack when it gets old. It can be done, they weld up old crew boats all of the time
  5. TeKeela
    TeKeela Member
    NC & Puerto Rico
    Friend of mine ran a 62' striker, Hakvoort built, installed a hydraulic American bow thruster. No issues and it was a great help getting that thing to move off a dock or maneuver in tight quarters with all that windage. My profile name is in honor or the owner, he was a very friendly guy and we got to use the boat whether he was around or not. Love those boats. Love the beam!
