Click for Northern Lights Click for Mulder Click for Burger Click for Mag Bay Click for Westport
shaft size
Discussion in 'Technical Discussion' started by captt3, Apr 1, 2014.
  1. captt3
    captt3 New Member
    Reedville Virginia
    I have a 60 foot boat, twin diesel engines , 2 and 1/2 to 1 reduction transmissions, and 24 inch wheels 19 inch pitch. What diameter shaft would you recommend.
    Twin diesel trawler or fast planing hull? How much horse power are you going to load on those wheels?
    If your over 500 hp, 2 inch minimum, prefer 2.5 inch shafts.
  3. NYCAP123
    On the 56' Hatt I run (74,000#) we have 2 1/2". Are there no shafts on to compare?
    horsepower is your most important consideration when picking shaft size....how much HP do you have? I have seen 2 1/2" shafts in everything from a 75' Jim Smith with 2000hp engines (splined shafts/no keyway) to 2 1/2" shafts in a 45' cabo with 1000hp c18's
  5. captt3
    captt3 New Member
    Reedville Virginia
    sorry I left out horsepower, 2 4 cylinder Detroit's 120 horsepower each. Hull speed proximately 6 knots
  6. RER
    RER Senior Member
    Newport Beach CA
    24" x 19" props on a 60 footer? ...what's between the gears and the wheels now?
  7. Capt Ralph
    AND, how long are the shafts? how many supports?
    120 hp can use 1 1/4 to 1 1/2 inch if not to long.
  8. NYCAP123
    Pushing a 60' boat with 24" props, really? (not being a wise guy, just surprised).
  9. captt3
    captt3 New Member
    Reedville Virginia
    the shaft is 17 feet long supported at four points.
    her shaft is now two and a half inches I think that is way too big .
    P. S. I am new to this and want to thank everyone for their immediate support.
  10. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    As other poster has pointed out the largest factors are HP and shaft length; as well as number of supporting struts. Generally on higher speed vessels with 2100+ HP the shaft may be 4 inch. 1700-2000HP 3 1/2 inch. 1250-1650 is 3 inch. I base this on sportfish models I've worked on. IDK about 60 footers with 120 HP.
  11. Capt J
    Too big is much better than not big enough. Well, you have a lot of reduction and swinging a large wheel (for the HP of engines) so it is going to put more stress on the shafts. Shaft length and number of struts are another consideration with shaft size. What model detroits do you have, and are you sure of their HP.
  12. Bamboo
    Palm Beach, FL
    Sounds like 4-53's and I agree 2.5 is far too large unless the length is the reason. However it is a non planing vessel so reducing the shaft diameter will do little to increase speed or efficiency which would pay for the change.
  13. Capt Ralph
    If you already have 2.5 inch shafts in place. Smile allot and leave them alone. At 17 feet, I would think two piece shafts and a muff. Four bearings and 17 feet may require 2.5s.
    Your not making the speed to worry about extra drag. If you ever do change shafts, please contact me. I have a 2.5 that is cork screwed.
  14. NYCAP123
    It seems odd to change what was designed for the boat. Could you explain your reasoning or what you're hoping to attain?
  15. captt3
    captt3 New Member
    Reedville Virginia
    the Detroit diesels are 453s. the longest unsupported stretch of the shaft is 6 feet.
  16. captt3
    captt3 New Member
    Reedville Virginia
    I am looking for the smallest safe shaft size because of a dispute I am having.
  17. Capt Ralph
    O K, you hooked me, What Dispute?
    If there is anybody who can pull up to a water side bar and have a dispute, it IS some of us here.
  18. NYCAP123
    Considering that most manufacturing standards today are based on 'how little can we get away with' I'd be hesitant to reduce the size of a shaft from that recommended by the manufacturer unless I was highly qualified to make such a determination. Would hate to jam the throttles to beat a swift current or touch a piece of flotsam and have a shaft snap like a twig.
  19. Capt J
    And you are going to spend 10,s of thousands to change the struts, propellors and the coupler as well as buying new shafts on a boat that is decades old????
    Call Frank and Jimmy's in Ft. Lauderdale, give them all of your specs and they should be able to calculate what shaft size you need. Other than that, why waste our time with your dispute with someone else. The engineers who built your boat decided on that shaft size for a reason, and you are obviously not more knowledgable on the subject than they are.
  20. Bamboo
    Palm Beach, FL
    Shaft size determination can be scientific or it can be whatever the design team at the builder decided on. On the Donzi they decided to go with a 4 inch shaft on the 65's with 16-92's rated at 1450 HP. They "overbuilt" the whole boat so they went with a oversize shaft. At 1450 HP Viking goes with a 3 inch shaft. There is no real reason a sub 300HP engine needs a 2.5 inch shaft. Sometimes the builder does thing that defy reason. Just look at the threads about the lack of ease in boarding some newer boats and putting the helm electronic in the direct sun...
