Click for Glendinning Click for JetForums Click for Mag Bay Click for Abeking Click for Mulder
Norcold refrigerators
Discussion in 'Technical Discussion' started by 36mainship36, Feb 23, 2014.
  1. 36mainship36
    36mainship36 New Member
    Avalon, New Jersey
    Time for replacement. Any thoughts on DE0061R ? .or if anyone has better suggestions
    Lou R.
    36mainship
  2. SeaEric
    SeaEric YF Historian
    out on the dock
    Conventional wisdom seems to suggest that Tundra and Isotherm are making some more reliable, direct replacements for the failed No-Cold units. I'd look around at several alternatives.
  3. Capt Ralph
    Inquiring on a DE0061R or replacing it? If I recall the later nor-colds have the newer DanFoss compressor. This system is the basis on most of the newer refrigerators out there.
    I pronounce them "never cold" because they never really seem to get cold enough.....I'd look at other alternatives personally.
  5. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Lots of people put in home style units and run them off an inverter.
  6. RER
    RER Senior Member
    Newport Beach CA
    I would move away from the Norcold as well. R&R'd one because it was running 20 hours a day. Now, so does the new one and it's just as loud too.
    I'd look at Tundra and Nova Kool or a non-marine 110V unit if that fits your program.
    Yeah, the U lines are a lot better if you're looking in the typical nevercold category.....at least they have good sized compressors on them.
