Click for Abeking Click for Burger Click for Northern Lights Click for Furuno Click for Walker
Help with mould(mildew) ? rib boat
Discussion in 'Technical Discussion' started by tony85, Feb 12, 2014.
  1. tony85
    tony85 New Member
    Trogir
    Hello, I need help, I have rib-inflatable boat made of hypalon , boat is not old 3 years only but have moulds , did somebody know how to get it off ?? You can see on picture, THX :)
      40 KB
  2. Dave Stranks
    Dave Stranks Member
    Coal Harbor Vancouver
    this is hard to believe that its growing on the tubes
    better talk to the maker and ask if they have seen this before also if the material is sensitive too with cleaning products.
    I know that high PH cleaners will remove this kind of stuff with a soft brush
    Once you get it cleaned I would wax it;to seal it up I do mine once a year just skid the step treads
  3. tony85
    tony85 New Member
    Trogir
    I ask but nobody see this beafore and do not have any advice for now, here is link of boat : Maestral 555 - Maestral
    I hope someone has a similar problem and managed to solve it with some product, any advice help
    what kind off product you recommend ??
  4. AMG
    I have used "methylated spirit", but not sure if mine is hypalon. Try on a small area first and flush with water after...
  5. Beau
    Beau Senior Member
    Beaufort, NC
    Looks like its on the fiberglass floor boards also. Is it possible that its from diesel exhaust? Where do you keep the inflatable. Just a thought.
  6. tony85
    tony85 New Member
    Trogir
  7. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
  8. tony85
    tony85 New Member
    Trogir
    AMG- thx for advice but that mybe distroy hypalon :/
    Fishtigua- I look store but they don't have similar product for this problem, I try to contact them for advice.thx
    Did somebody else have similar problem ?
  9. AMG
    It is just about €4 /litre so it is worth a try, and diluted with water you can clean almost anything without causing damage... it is perfect for canvas with mould as well, it sort of kills it..:)
  10. tony85
    tony85 New Member
    Trogir
    ok I'll try a small area, I hope you will succeed, thx :)
  11. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    It's not uncommon by any means to see "mold" growing in the pores of hypalon. And it can be tough to get out. You could start with bleach and then try degreaser and Magic Erasers. Also orange hand cleaner with pumice in it works well. It takes lots of elbow grease no matter what you use. And you may not get it all out no matter how hard you scrub. After the cleaning follow up with 303 Protectant.
  12. Yachtjocky
    Yachtjocky Senior Member
    Mold
    Wait until CaptJ has finished moving boats into the show and he will tell you what to use. I guess that is where he is but may be away on a trip.
  13. RB480
    RB480 Senior Member
    New Buffalo, MI
    Heavy dousing of simple green and use magic erasers to scrub it in. Rinse well and protect with 303.
    What have you been using to clean it for the last 3 years?
  14. Capt J
    It's a touch on the harsh side, but I haven't seen any longterm effects with it. But I have used bleach or 50/50 bleach and water.....and mixed that with a lot of soap....Joy or Dawn......the sudsy soap makes it stay on the tubes without running off like straight bleach....brush on with a washdown brush.....let sit 5-10 minutes......that combined with a scrub from a brush or magic eraser usually takes it off......Krud kutter also works pretty well and you can find that at Home Depot etc.....
    The orange gojo with pumice sometimes works really good and sometimes not so good......
  15. RT46
    RT46 Senior Member
    I have had two white inflatable and have struggled to keep them clean looking.
    Also once the white ones start to age a bit they always seem to look bad.
    My last two inflatables have been grey.
    Although they don't look as pretty when new, they look new a lot longer and are easier to keep clean.
    I have had luck cleaning the older white with soft scrub and a sponge, ones once they get pitted and have dark pores. I remember using the soft scrub with bleach and making sure not to be too abrasive to the fabric and rinsing off quickly.
    I have also used acetone, but be very careful to wipe on and wipe off and rinse with water. The acetone will delaminate the glue that keeps the inflatable together if left on.
    Always test a small part of the boat first.
    By the way, one thing that never seems to work for me is any product that is marked
    "Inflatable Boat Cleaner"
  16. thatcher
    thatcher Member
    nassau, bahamas
    rib
    Get some Gas and a match. I've had this problem and used clorox bleach, ajax. mixed it together. It took a few applications but it came out fine. It will never be the same but its white. With the rubber rub rails I had pitting so I sanded with 80 grit and turned out well. On nice days take off the cover and let the boat get some sunshine.
  17. Marblehead01945
    Marblehead01945 Member
    Marblehead
    Permanon Paste
    I have tried a bunch of things and I keep coming back to Permanon paste and the applicator pad.In fact, I use that for a lot of things. Its kind of like a soap type paste. It requires some elbow grease but it looks super good after the application. Once done, I just spray on some Permanon and call it a day.
    R
