Click for Rybovich
Click for Westport
Click for Christensen
Click for Heesen
Click for Lazzara
Click for Nautical Structures
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Diesel Electric Propulsion
Reply
Old 11-17-2005, 10:58 AM   #31
MacMcL
Registered User
Passage Maker Magazine recently did an article on a DE retro fit to a smaller vessel (40'or 50") using motors to turn the props as opposed to pods. Quite interesting, and they intend to follow up with future coverage. Seimens seems to be the leader in providing the equipment right now.
MacMcL is offline   Reply With Quote
Old 11-17-2005, 11:58 AM   #32
brian eiland
Senior Member
brian eiland's Avatar
Motor Sealing and Bearing Failure
Thanks Godger
Those bearing failure references were interesting, but lacked some details. The reports stated that there were 2.5 foot dia bearings that support the shafts, but failed to mention the trust bearing sizes or types, even while it stated, "The bearings are apparently failing under thrust loading."
I find it somewhat difficult to understand that the peripheral bearings would fail under thrust loading. I find it much more likely that the thrust bearings would fail, as they are being asked to absorb both forward and rearward thrust loads. Possible the 'lips' of the peripheral bearings are being used to absorb the thrust loads, and these are too small in total area as a design effort to keep the overall diameter of the pod to a minimum. But even this doesn't make sense as the motor unit is already a bigger diameter itself.
Note that these podded designs house an electric motor that must be sealed against the sea water, as well as the likely hi-capacity bearing lubrication medium. The electric motors of the newer generation 'peripheral drives' is a permanent-magnet DC unit that is not being isolated from the sea water, nor are its bearings.
brian eiland is offline   Reply With Quote
Old 12-16-2005, 08:05 AM   #33
thomhack
Registered User
Azipod propulsion
Hi all,
I just joined this forum. A quick note to make sure that you have seen the feature in issue 69 of The Yacht Report ?
http://www.theyachtreport.com/Articles/TYR69myair.pdf
Send me an e-mail, if you want more info.
Regards to all,
Thomas Hackman
ABB Marine
thomas.hackman@fi.abb.com
thomhack is offline   Reply With Quote
Old 12-16-2005, 12:31 PM   #34
YachtForums
Publisher/Administrator
YachtForums's Avatar
Hi Thom,
Thanks for joining.
Lurssen has diligently persued permission to publish images of AIR, but to no avail. We had hoped to cover some of the technical achievements in the form of a feature review. If this comes to pass, I hope you'll be able to share some insight.
Glad to have you aboard.
Carl
Old 12-22-2005, 07:55 AM   #35
thomhack
Registered User
Carl,
Just send me a line and IŽll try to help you.
Merry Christmas to all.
Thomas
Old 12-22-2005, 07:31 PM   #36
bulwark102
Registered User
There is a Nordhavn 72 currently being built with DE propulsion, go to nordhavn.com for details.
Their conclusion so far is that it will be more expensive to build, but can be more fuel efficient by being able to more accuartley match power generation to the speed of the vessel, there is greater redundancy as all engines including the generators are potential power sources.
Perhaps one of the most interesting points is that full torque is available as soon as the propeller starts turning, which should help when docking.
It will be interesting to see how it performs.
bulwark102 is offline   Reply With Quote
Old 12-24-2005, 03:57 PM   #37
AMG
YF Moderator
AMG's Avatar
Diesel Electric Explorer
A member of the YachtForums asked me to make a "Highlander green" version of my 70 m design Polara. Also to add a couple of ABB Azipods.
And since it is Christmas, his wishes came true...
AMG is offline   Reply With Quote
Old 12-25-2005, 12:36 AM   #38
Texas_Dragon
Registered User
Texas_Dragon's Avatar
Green Is Great!
Beautiful, Lars! Thanks!
Texas Dragon
Texas_Dragon is offline   Reply With Quote
Old 12-25-2005, 01:52 AM   #39
Arniev
Senior Member
Arniev's Avatar
Thumbs up
Awesome ...
Arniev is offline   Reply With Quote
Old 12-25-2005, 02:20 PM   #40
Texas_Dragon
Registered User
Deck Plans
Lars,
I've searched the forums and have found what seems to be your first posted rendering of the 70 Meter Polara Explorer. Do you also have the general arrangement for the decks that you show for many other of your designs?
I'm drooling at the thought!
Texas Dragon
Old 12-25-2005, 04:22 PM   #41
AMG
YF Moderator
AMG's Avatar
Sorry, I have made no complete plans on yachts bigger than 180 feet. Here are the outlines for the decks if you would like to draw them in yourself...
As many yachts, this one can also be diesel electric with shafts instead of pods. I am not sure what I should build today, it would be nice to have some first hand reports from the yachts now launched with Azipods.
/Lars
Old 12-28-2005, 11:08 AM   #42
thomhack
Registered User
Lars,
The feature in The Yacht Report #69 includes a first-hand report on the sea trials and first months of operation, made by Steve Lloyd, the Chief Engineer. I can send you a copy by e-mail, if you wish.
Also, I can prepare for you a power plant spec (with equipment dimensions and weights), if you want to fit it into your GA. Just give me some more details on the power requirements for the Polara Explorer.
Nice design, by the way. The non-bulbous bow tells me she is ice-classed. What class ?
Regards,
Thomas Hackman
ABB Marine
Old 12-28-2005, 11:19 AM   #43
AMG
YF Moderator
AMG's Avatar
Thanks Thomas, IŽll contact you by e-mail.
On the ice-class, since she has no buyer yet, I donŽt know. But you are right, with this bow she can break pretty heavy ice, with removable stabilizers and ice eating props fitted...
Old 12-28-2005, 01:23 PM   #44
Mark in SBA
Registered User
I've gotta laugh at all this "new" technology.
All the anticipated cost savings these technologies are supposed to realize go up in smoke with the first unscheduled dry docking. There's nothing intrinsically "neat-O" about DE, and it's been used landside in locomotives for decades, albeit in moderate horsepower applications. The real technology driver for DE isn't the mechanical stuff - it's the solid-state motor controls.
DE makes sense for the cruise liners because it consumes less space, offers better siting flexibility within the hull, and can be tailored to reduce vibration by operating the engine within a narrow band. The downside to the azipods is 50% of the drivetrain is sitting outside the hull.
I'm with Codger - traditional shaft and in-hull AC motor setup. The slight loss in prop efficiency is made up with the ease of inspection and maintenance.
Mark in SBA is offline   Reply With Quote
Old 12-28-2005, 02:05 PM   #45
brian eiland
Senior Member
AC/DC
Quote:
All the anticipated cost savings these technologies are supposed to realize go up in smoke with the first unscheduled dry docking. There's nothing intrinsically "neat-O" about DE, and it's been used landside in locomotives for decades, albeit in moderate horsepower applications.The real technology driver for DE isn't the mechanical stuff - it's the solid-state motor controls.....
I'm not an electrical wiz, but I believe a substantial portion of the 'new technology' in this realm relates to the use of DC systems rather than AC systems. And the use of permanent magnet motors and generators. This makes some of the new technology "neat-O".
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 10:06 PM.
Click for Heesen
Click for Trinity
Click for Burger
Click for Horizon
Click for Broward
Click for Quantum
