Click for Walker Click for Delta Click for Perko Click for Northern Lights Click for Mulder
Sea strainers/seacocks with patina green
Discussion in 'Technical Discussion' started by CSkipR, Jan 16, 2014.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Just wondering whether anyone has found a product that will easily remove the patina color that forms on the brass/bronze seacocks. I realize it doesn't hurt anything just would like to make it go away and don't want to scrub with a wire brush as not worth it.
  2. JWY
    JWY Senior Member
    As an fyi, the patina color is called verdigris. I'm sure you're looking for a better answer than this, but just thought I would throw it out there.
  3. K1W1
    I have heard Lemon Juice works but the green is actually a protective layer so it does no harm leaving it there.
    Brush them with Ospho, it will bring them to a bright bronze. Once they're clean, then spray them down monthly with Corrossion Block.
  5. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    What K1W1 said. But most any acid or acid based cleaning product will do the trick. If you want to keep it off for a long time after you clean them, try coating them with a ceramic clear coat. Other wise you could just clean them and paint them white.
    I don't mind whether the seacocks are a shiny bronze, or green.....but for some reason I cannot stand when they're painted white......don't ask me why.......LOL I think because you can see a natural seacock from far away......whereas if it's white and you have white hose going to it, you have to get much closer to really see it's condition and if there is a leaking fitting or something (as dried salt it white also).
  7. Pascal
    I've heard that Preparation H works wonder ...
    For a number of a n a l problems":)
    Sorry couldn't resist... I wish all I had to worry about was a bit of vert de Gris on my strainers :)
  8. Old Phart
    Old Phart Senior Member
    I dunno
    "Learn something new every day", they say.
    Thank you.
    P.S.- Probably why some give me a strange look when I mention aerugo. ;)
