Click for Ocean Alexander Click for Perko Click for Cross Click for Abeking Click for Westport
Marine Gas Engine Life Expectancy
Discussion in 'Engines' started by brian eiland, Dec 22, 2013.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    I saw a number of references to gas engine life expectancy in this article....
    Marine Engines : Gas Engines - by David Pascoe, Marine Surveyor
    ...but what surprised me is nothing about 'engine hours' of life'??
    I know that many marine engines are equipped with 'hour meters', and certainly there sure be some approximates as to engine life in man-hours.
    How about it, any folks want to contribute their figures to that subject?? I've been told to avoid anything with over 1500 hours on it as likely they all requires rebuilding or replacement as they approach 1800 hours. ??
    I would say 1500 hours is a reasonable number for gas inboards. BUT, I've seen many many of them die under 500hours because a lot of gas inboard owners are cheap and don't do the proper maintanence and don't change exhaust manifolds and risers every 5 years or overheat them. I've also personally known gas inboards that have gone 4,000 hours with no rebuilds. But you see many die an early death. A compression test, seatrial, check exhaust manifold riser temps at cruise speed and good oil pressure would be your best guide to their current condition rather than hours. Also keep in mind, that there are a lot of VERY heavy boats that should never have gas engines in them, with gas inboards like all of those 40'+ carvers, silvertons, sea rays and others they threw them in.
  3. brian eiland
    Engine Surveyor
    Anyone know of a good engine surveyor up in the Annapolis, Kent Island, Eastern Shore area??
  4. SeaEric
    SeaEric YF Historian
    out on the dock
    I have used 2 surveyors on the Eastern Shore for my own personal yacht purchases. Both will do and have done gas engine compression tests. Reno Panico, Atlantic Seaboard Marine Surveyors and Steve Sanders, East Coast Surveying. Both are SAMS surveyors and their contact may be found on the SAMS site along with plenty of others. Membership Roster for Maryland
  5. brian eiland
    Sent you a private email. hope it came thru OK?
    Turns out both of them are headed south today and tomorrow.
  6. SeaEric
    out on the dock
    Got it. I replied. Call my cell if you want to talk.
  7. 1000 islands
    1000 islands Member
    Ivy Lea
    I agree with Capt J but in many cases even not so heavy boats have the wrong size engine to power them. I currently have a Carver 3607 that weighs around the 20,000lb mark and she is powered with twin 8.2L Blue Water Mercruisers, which I think is adequate but at the limit. The boat would be better off with diesels, but it all has to do with the cost.
    There are boats in my marina about the same size with 5.7L Mercs and they average about 1500 hours before re-builds.
    I see many 20 - 30 foot boats that are way under powered and it seems to be related to cost. My neighbour had a 25 foot Searay with a 5.0L Merc and it needed a re-build at 550 hours.
    To me, the manufacturers and marinas should consider the life of an engine when coupling it with a hull rather than the current attitude to make it as financially attractive to a buyer.
    This topic is a sore spot to me because I have seen too many young people that try to get into boating and after just a couple of years need to rebuild the engine because it is not the right one for their boat.
  8. stringer bell
    stringer bell Member
    Jupiter
    Lifespan greatly varies between FWC and RWC engines. FreshWaterCooled motor can last 1500 hours with minor maintenance, while 500 hrs on the RawWaterCooled motor is about the limit, even with regular flushing after use. On diesel engines it is quantity of fuel passed through the motor that determines lifespan.
  9. olderboater
    This was always something I saw on lakes. We had just a 30' bowrider but had the largest engine options (430 hp) versus many who were buying with the smallest (300 hp). In Mercruiser you're talking the 8.2 Mag vs. the 350. Volvo the model is 430 CE vs. 300 C. We didn't have it really because of the top end speed but because we felt we taxed it a lot less in normal operation. Where those with smaller engines are running WOT we'd be running a comfortable 2/3 cruising speed. We did have regular service, used the boat constantly, and never shut it down for winter or winterized it. Rarely did it ever go more than a week between uses and never more than two weeks. Never out of the water except for service and bottom cleaning. When we sold it, it had 1200 engine hours and ran perfectly. Reached the same RPM's and top end as the day it was new.
    I saw the most disappointed boat users were those with underpowered boats and they were also the ones with the most problems. Now this doesn't carry over to larger boats, displacement and semi-displacement, and diesel installations. I'm just talking about gas engines in modest sized boats intended as planing boats. The reason for the underpowering is simple. Cost. And the dealer isn't about to tell you in most cases that you'll be unhappy with it.
