Click for Northern Lights Click for Ocean Alexander Click for Delta Click for YF Listing Service Click for Glendinning
I’m looking for a simple autopilot
Discussion in 'Electronics' started by P46-Curaçao, Dec 9, 2013.
  1. P46-Curaçao
    P46-Curaçao Senior Member
    I’m looking for a simple autopilot, that can just hold a course if I enter the compass degrees.
    When I bought my boat, there was a non working Robertson AP200DL installed, and the only part survived, is the hydraulic pump and seems to be in good shape!
    Does anyone used this old pump in combination with a simple autopilot?
    FYI, it has nothing to do with money, I just want to keep this simple.
    (I have brand new Garmin 740s GPS with radar and probably use it ones a year…)
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    In many cases the pump can be used with another brand of autopilot. Just find the autopilot you want to use and check with the manufacture if the pump will work with it.
    What with all the advances in electronics these day I'm not sure there is a basic unit around anymore. So I suggest just the least expensive unit you can find from one of the reputable manufactures and go from there.
    Perhaps look for a close out sale on a last years model kind of deal if you don't want buy used.
  3. SeaEric
    SeaEric YF Historian
    out on the dock
    I also have the Garmin 740s chart plotter. This season I added the Garmin GHP 20 Autopilot. Like you suggest, I mainly just reach up and push the button and have it steer the boat. It works very well. I highly recommend this unit. Especially if cost is not the big factor as it is a bit pricey with install.
  4. Caltexflanc
    Caltexflanc Senior Member
    North Carolina
    I have used a ComNav basic unit on a 49 Grand Banks and found it very user friendly, they have a good reputation, do a lot of commercial business. You should give them a call and discuss your objectives.
    ComNav
    Another simple unit is the Raymarine s1000, you may find a used one, not sure if it would work with your pump.
    The 200DL is a pretty reliable unit, that's what we have on our boat. Have you discussed the situation with SimRad for repair or upgrade?
  5. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    What size vessel? If money is not a issue then buy all new stuff; there is no value in trying to save an old pump which may have problems down the road.
    The Simrad AP28(+ related system parts) I put on the 65 footer less than two years ago is simple enough. Turn it on and you go straight- you want to turn left? Turn the dial left. Turn right? Turn the dial right. While it's able to do all sorts of stuff I rarely use anything but the dial. It replaced a Robertson similar to what you have and the transition was easy.
  6. P46-Curaçao
    That's the way I would like to go Bamboo, thanks for you input.
    Just turn the dail left and right is exactly what I want!
    I have a 46ft Post
  7. P46-Curaçao
    Hi SeaEric, just curious, which parts did you had to order to complete the Garmin GHP 20 Autopilot in combination with the 740s with radar?
    The GHP20 display, the pump I suppose, something else?
    Thnx, Eric
  8. Bamboo
    Palm Beach, FL
    Get a good installer to do the work if you can. I'm very happy with the AP28, and it's had zero issues so far.
