Click for Abeking Click for Mulder Click for Cross Click for JetForums Click for Northern Lights
exhaust lagging
Discussion in 'Technical Discussion' started by thatcher, Nov 28, 2013.
  1. thatcher
    thatcher Member
    nassau, bahamas
    good day everyone, happy thanksgiving to all the americans. My exhaust lagging is starting to stain. It seems to be from the inside - out, and no cleaning products are working. Is there a cleaning solution for this or is replacement the way to go. Thanks in advance
    thatcher
  2. K1W1
    That is certainly unusual looking staining.
    If you unwrap one of the blankets does the brown stain appear on the inner surface as well?
    If it is from the inside I think the only way to improve it will be to replace it if you cannot find a paint that can be applied to it.
  3. Marmot
    It appears to be only on the high spots. I think it might be from using cleaning products or abrasion from something. It looks like the aluminum coating is worn through.
  4. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    Agreed
  5. NYCAP123
    Exhaust leak?
  6. K1W1
    Not normally brown
  7. thatcher
    thatcher Member
    nassau, bahamas
    gobble gobble
    Thanks everyone - No exhaust leaks, I havent used any products until now, just a wipe clean. I'll take a look at that paint. Nothing seems to penetrate the top side, when I get to the boat I'll remove that piece and see what's underneth.
  8. Capt Ralph
    Looks like something or somebody has been rubbing on it. Is this riser near a entrance or hatch way? It it leaned on to access something in the E R?
  9. thatcher
    thatcher Member
    nassau, bahamas
    Its at the entrance to the engine room, and has a railing in front of it.
  10. Capt Ralph
    It's looks like the raised/high spots are worn. The low spots, like under a fold or crease, is not stained. Body oil/sweat or towel with some harsh cleaner/chemical has laid over it. I don't think it's from under the blanket.
    How does the other riser look?
  11. Capt J
    That's not staining, that's the finish wearing off.
  12. thatcher
    thatcher Member
    nassau, bahamas
    can this be painted with high heat paint?
  13. K1W1
    Get a can and try it, it will be the cheapest solution if it works.
  14. JWY
    JWY Senior Member
    Looks like this might be a Firwin product. Who is the manufacturer?
    Judy
  15. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    +1 to that.
  16. thatcher
    thatcher Member
    nassau, bahamas
    I ended up painting it. Came out great. I'll send pics on Monday. Thanks to all
