Click for Nordhavn Click for Glendinning Click for Abeking Click for Westport Click for JetForums
Battery testing (little ones)
Discussion in 'Technical Discussion' started by JWY, Aug 13, 2013.
  1. JWY
    JWY Senior Member
    Try it with a Triple A... :rolleyes:
    I've found that dead batteries like AA's seem to feel lighter than new ones. But I don't have anything to measure something that light so it's just seat of the pants.
  4. Marmot
    Well duh ... all that electricity went away to make light or sound didn't it?
    Doesn't your boat weigh less when the fuel tank is empty?
  5. Yachtjocky
    Yachtjocky Senior Member
    Heavy stuff
    Well duh....why do you think cables sag between utility poles, that electricity is heavy stuff. :D
  6. Marmot
    There you go ...
    What I could never figure out is how clouds of the stuff can just blow away when it leaks out.
  7. Yachtjocky
    Stuff
    Hope NYCAP123 is reading this, he now knows why he is only getting 175 volts, try measuring the power when it is not windy !
  8. tirk
    tirk Member
    london
    I'm reminded of one of my favourite Dilbert cartoons. :D
  9. Marmot
    Well, how else could you make it lighter besides running the battery flat?
  10. Old Phart
    Old Phart Senior Member
    I dunno
    Cut off the ends.
    Glue the ends back together.
    Throw away all that unnecessary dead weight between the ends.
    The battery will be lighter.
    If a wet cell, turn the battery over.
    Let the fluid drain.
  11. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Today I tried 8 different A,AA,C,D batteries that all tested at 1.5v or higher. Dropped each of them from approximately 1" and 7 out of 8 fell over. Not sure if that was too high or what.
