Click for Abeking Click for Abeking Click for Delta Click for Mag Bay Click for Mulder
Mercruiser - Strange Issue
Discussion in 'Technical Discussion' started by 84far, Jun 28, 2013.
  1. 84far
    84far Senior Member
    Brisbane, AUS
    Hi everyone.
    While I wait on the mechanic, thought I would ask on here as well.
    Basically, my brother was heading out the other day on our Bertram. It has twin Mercruiser 165hp 1988 (Original motors/drives). He got out to Huybers beacon (10mins out of the harbour) when the starboard motor lost drive, felt like they hit something, but pretty sure he didn't. The revs went up a lot, but was quickly brought under control.
    My first thought was the bush went, but we had a quick look the other night and it seems to be fine (we think), we put the motor in and out of gear and turned the prop, and it felt like there was still friction (gears connected), and was the same as the port prop.
    Any thoughts, on where to look or check...? Thanks everyone, cheers
    Far
  2. 84far
    84far Senior Member
    Brisbane, AUS
    We also checked the gear cable on the motors, they also seemed to be fine. Cheers
    Far
  3. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    A UJ fork yolk may have let go on the spider. I've seen them punch out of the top of older drives.
  4. 84far
    84far Senior Member
    Brisbane, AUS
    Thanks Fish, will this show signs of breakage, cause at the moment we can't really see any signs of anything broken (no filings/grease/oil out of place).
    I was going to remove the leg and inspect further, I'm just not a grease monkey :rolleyes:
    Far
  5. NorCalBoater
    NorCalBoater New Member
    California Delta....for now
    Sounds to me like you spun a hub on the prop. Hard to tell trying to turn by hand. I would take the prop to a shop.
  6. K1W1
    Put it in gear, if you can turn one side when in gear by turning the prop there is something wrong with either the prop bush or the gearbox itself.
  7. 84far
    84far Senior Member
    Brisbane, AUS
    Thanks guys, I'll go and have another look tonight. It is pissing down here with rain and might have to swim to the dry dock. :eek:
    K1W1, I think my brother tried that trick, but I'll double check. Cheers
    Far
  8. 84far
    84far Senior Member
    Brisbane, AUS
    Update -
    Well I put both motors in gear -
    Starboard prop - was a tight turn for a quarter rotation, then would free up.
    Port prop (Same) - was a tight turn for a quarter rotation, then would free up.
    Both would have the same characteristics.
    Put both motors in neutral.
    Starboard Prop - Would be a constant rotation - felt loose/free.
    Port Prop - As before - was a tight turn for a quarter rotation, then would free up.
    Thoughts...?
    Far
