Click for Cross Click for Westport Click for Burger Click for JetForums Click for YF Listing Service
Fuel Transfer pump on 68 Hatteras
Discussion in 'Hatteras Yacht' started by captbluewater, Jun 12, 2013.
  1. captbluewater
    captbluewater New Member
    Los Suenos
    I recently replaced one of my fuel transfer pumps and pump is not moving fuel. I can take the suction line off pump and I can feel suction. There is an electronic valve in front of that pump that you can select which tank you want to pump from. Has anyone had problems with this valve. Thanks
    Anything is possible. I have not heard of problems with those valves. The hatteras I've run have had a manual valve to switch between the 3 transfer tanks. Also, there is a filter installed by Hatteras, usually after the selector valve and that may be clogged.
  3. franzmerenda
    franzmerenda Senior Member
    La Spezia, Italy
    On my transfer system I had to replace this...
    You can find it online in the Parts Catalogue of the most important Hat Stockist
  4. captbluewater
    Los Suenos
    Is that the flow sensor meter.
  5. franzmerenda
    La Spezia, Italy
    Yes it is!
  6. captbluewater
    Los Suenos
    Thanks for help. I wired the new motor like the last one and I had to reverse the wires.
