Click for Westport Click for Westport Click for Abeking Click for YF Listing Service Click for Ocean Alexander
Bow Thruster overhaul/refit
Discussion in 'Technical Discussion' started by cdg, Apr 6, 2013.
  1. cdg
    cdg Member
    wellington, new zealand
    My Wesmar DPC-50 bow thruster isnt working. Seems the shaft doesnt want to engage under load. Its only 12 years old; and given we're mostly at sea, isnt used often. Wesmar said 'we no longer support that model - which ir remarkable - so no spares, and please buy a new one! So can someone advise: a) a thread for overhaul/refit info, or b) where I can get spare shafts?
    Thanks in advance.
    C
    Where does "the shaft doesn't want to engage under load" happen? Pinion gear? motor coupling? wheel hub or clutch? Motor rolls over when engaged? Breaker triping ?(Assuming it's electric). What did the oil look like when last inspected? OR any last inspection results? Was it inspected on last haul???
    Your kinda of thin in your failure description and history.
    I have found that even the most ugly failures are usually something simple.
    Give us a little and maybe we can help you fix it.
    Have you checked to make sure the propellor is not spinning the hub? This is by far the largest problem in bow thrusters.
    I agree that you're opinion is very vague
  4. NYCAP123
    It's not unusual for a 12 y.o. anything to be no longer manufactured and parts not available today. I'd check the prop, and if beyond that get a new thruster. If the shaft is indeed bad, what else is worn out and ready to go? If you insist on trying to repair, then it may be time for a trip to a bone yard.
  5. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Have a look at the plate on the motor. Wesmar used to buy them in and the brushes often go. Motor brushes can be bought to fit most any one of them.
  6. cdg
    cdg Member
    Thanks guys - will get some more info and post back. My apologies for apparent vagueness.
  7. cdg
    cdg Member
    Thanks guys - love it!
    Apologies for the lack of info - wasnt intending to be vague. My engineer reported:
    I barred the shaft and couldn't spin the props. I then disconnected the motor( hydraulic) from the gearbox. I ran the motor it sounded fine, and turned with force. Had a tech down to look at motor, he agreed motor sound fine and didin't it needed to go the workshop. I then had the props spun and watched the shaft from gearbox to motor spin while disconnected. It turns but not consistantly leading me to believe that some gears have spat teeth. I got a mate coming down tomorrow to spin the props while i hold the shaft and confirm that's the problem.
    So, hope that provides the info you need? Many thanks again in advance. cheers
  8. Navatech
    Navatech New Member
    Hollywood, FL
    OK, so clearly the motor is OK.
    Inconsistent spinning of the props would lead to inconsistent turning of the geas. Get a couple of walkie-talkies to make sure that you know when the props are being spun.
    If you still see inconsistent turning of the gears it would tend to indicate damaged gears. Hopefully you can source these and rebuild the thruster.
  9. Seaclusion
    Seaclusion New Member
    PNW
    If it is a hydraulic motor, then to engage the thruster there is a rubber donut on the shaft attached with set-screws. If the set-screws back off, then the donut will not engage. Been there, done that with a WESMAR. You may need a new rubber donut, as these do wear out.
    Doug Crim
    Seaclusion
