Click for Westport Click for Mulder Click for Mag Bay Click for Ocean Alexander Click for Abeking
Hull Vane
Discussion in 'Stabs, Tabs & Gyros' started by K1W1, Feb 13, 2013.
  1. K1W1
    Has anyone had any experience with this system?. Van Oossanen Naval Architects – The Hull Vane
    Heesen are said to have snapped it up for the new 65m, other than that I can't seem to find any actual vessels it has been used on although they state a Maersk Containership was amongst the successful trialists.
  2. wdrzal
    wdrzal Senior Member
    "The Hull Vane® only reduces the pressure resistance (not the resistance associated with friction).
    That sentence above makes it sound like Mr. Bernoulli's principle is at work in some way.
  3. YachtForums
    Not Bernoulli. Think Coanda. ;)
  4. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Didn't Oceanfast/Phil Curran try something similar with 'Ocean Seven'?
    Somewhere in the back of what's left of my mind, I remember talk of a foils being fitted at the stern sections. That was 20 odd years ago, so may be mistaken.
  5. wdrzal
    I know what you mean
    Wasn't there a sailboat that a feature was written about here at YF that instead of traditional sails the boat had vertical vanes shaped like a airfoil? I seem to remember 2 or 4 of them at least. Is this the same principle except the working fluid is water instead of air?
  6. karo1776
    karo1776 Senior Member
    Gone
    In aero... hydro and fluid dynamics... the important part really is where it comes all back together...
    The leading edge or bow is important and lots has been done to diminish bow wave and change their form... but much of the drag is created at the stern which is where these boys are trying to improve things.
    You know that rough turbulent "wake" that usually tails 'power' boats... ain't all prop wash!
  7. Old Phart
    Old Phart Senior Member
    I dunno
  8. K1W1
    That seems to be aimed at the top speed end of the market on a smal boat. Looks like a primitive sort of hydrofoil arrgt.
    A slight aside: I was sent a link about a bubbler system that was supposed to reduce drag by a considerable amount. It looked very promising in tank testing but failed to get anywhere near the same results in a real life trial.
    I am wondering if this vane thing will work out the same.
  9. Old Phart
    I dunno
  10. K1W1
    No,
    The one I saw was about tests conducted at the MARIN Institute in , the Mitsubishi one is a lot more recent.
    I wonder what percentage of the forecast savings of CO2 come from the manipulation if figures with total cargo tonnage v fuel burnt. Fuel burn on the Container Lines main routes has already been reduced by slow running, something that looks set to stay for the foreseeable future now the big players are building engines to suit this type of operation
  11. karo1776
    Gone
    How this "hull vane" works is by modifying the flow and induced drag conditions at the stern of the boat. If you think of the bow bulb concept it is similar but effecting the situation on the more important trailing edge of the hydrodynamic body/hull.
    In both the movement of the hull through the water induces kinematic energy effects in the water as the hull moves. Theoretically without considering wave or current action an ideally shaped hull would simply separate the still water and move it out of the way with a while imparting a minimum of disruption or "movement of the water"... only enough to allow the passage of the hull. The stationary water would be separated by the leading edge or bow and smoothly accelerated to just enough velocity to move out of the way to allow the shape of the hull to pass and then be equally and smoothly decelerated back to the still state at the trailing edge or stern. Only enough energy of movement "kinematic effects" and velocity would be imparted to to water to move it out of the way and then put it back together again with no net gain in movement or velocity in the water. The quantity of water moved; the distance it has to be moved; how fast it has to be moved, and how smoothly it is moved out of the way all add up to take energy. Reduce any or all of those and you reduce the energy required in doing so, except understandly smooth really means the less abruptly. Logically each of these translate into displacement mass of the hull, volume (which is directly related to mass), speed of hull and streamlining.
    This is the fundamental of all hydro and aero dynamics. The loss of energy in doing this is called drag or more properly induced drag of form... wherein the form refers to the shape of the hull or object moving through the water.
    However, water is viscus and this spreads the energy effects out to effect water not directly involved in the getting out of the way... so more water is effected by the viscus effects.
    Also, the velocity and energy imparted to the water take time to dissipate spreading the effects of the water moving out of the way.
    The hull vane is an attempt to use the velocity/kinematic energy of the action of the movement of the hull to direct that in a manner to effect and improve the effective streamline of the hull at the point of the trailing edge or stern wherein the water is put back as best as possible its original state prior to the passage of the hull.
    I have not gone into skin drag or turbulence to explain the real reason for this design... nor of the effect of propulsion.
  12. Innomare
    Innomare Senior Member
    Hull Vane explained
    Hi, sorry to revive an old thread, but there are some new developments on this front.
    Disclaimer: I work for Hull Vane - my apologies if this is considered as a commercial post, but I think the Hull Vane is such an innovative fuel saving device that it also has "news value". Along with ferries and naval vessels, yachts (of semi-displacement and displacement type) are in the category of ships which sail at a relatively high speed, where the Hull Vane can provide significant savings (>10%).
    To understand the working principles of the Hull Vane, the easiest is to watch this short video: Hull Vane - Fuel Saving Foils - YouTube
    Because clients for the Hull Vane are often ship or yacht owners and not shipyards, a separate company was established to market, design and produce the Hull Vane. It can easily be retrofitted to an existing yacht or incorporated into the design from the beginning.
    For more information, have a look on www.hullvane.com or catch up with me at the Monaco Yacht Show next week.
  13. K1W1
    Will u have a booth there?
  14. Innomare
    No, we'll be walking around.
  15. K1W1
    I don't have your number in the phone I have with me could you PM yours to me please?
  16. Old Phart
    I dunno
  17. Old Phart
    I dunno
  18. karo1776
    Gone
    I think it is a good idea. And, it should increase performance / economy as claimed. I should be an easy install too or retrofit too. So it should be a winner.
  19. olderboater
    Most innovations are new applications of old ideas. Hydrofoils and the concepts have been around for decades, actually centuries as they were first worked on around 1898-1900.
    If the Heesen application is successful and marketable, meaning yacht buyers will pay extra for it or will purchase Heesen because they have it, then I would expect to see an expansion. But we're in an industry of followers.
    I also don't know the cost of it, but if the application works well and the demand is there, then I'm sure others will come out with slightly different foil systems. Probably patent fights ensue.
    I think the concept of Hull Vane though is a very interesting approach as it's not meant to lift an entire boat off the water, it's just meant to provide lift enough to improve performance moderately. I think by being less extreme it could be far more practical and successful long term. I look at it potentially as another device that could be standard on large boats and thought of in the same way we currently think of stabilizers, as the norm.
    Harry Larsen once fitted hydrofoils on a 24' Bayliner.
    https://www.youtube.com/watch?v=w54-OEWulDE
  20. AMG
    ECO had a foil as well Francis Design
    But I am not sure it is only good to have something attached there? I think on new yachts, it is better to design a hull that is good enough without it...
