Click for Nordhavn Click for Comfort Click for YF Listing Service Click for Furuno Click for Westport
Engine Manufacturer Warranty Denied for Fuel Additives?
Discussion in 'Technical Discussion' started by Marmot, Dec 10, 2012.
  1. Marmot
    What tales do you have of engine techs or dealers telling you that using a fuel additive will put your engine warranty at risk?
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Volvo judge their own ideas as to what is reasonable fuel.
    Volvo warranty ....
    ... the use of lubricants or fuels which, in the reasonable judgment of Volvo Penta, are either incompatible with the Volvo Penta product or adversely affect its operation, performance, or durability.
    That covers their ass in most respects.
  3. Marmot
    Well, that blows a lot of smoke on the subject anyway ... nothing like surrounding a condition or consequence that requires technical precision to prove with a cloud of obfuscation and legerdemain.
    I have had 1 manufacturer take a fuel sample when having to warranty a rebuild on a just rebuilt 12v71. The fuel sample and oil sample were requested to the dealer by the factory 1 1/2 weeks AFTER the rebuild was started. I think the sole purpose was to find a reason to deny warranty coverage, considering the oil pan had been dropped and cleaned a week prior. The fuel had Diesel Kleen additive in it. They didn't say anything about the fuel additive nor did they deny the claim.
    I would take a hard look at the manufacturers warranty and what it says regarding fuel requirements. I think if the additive was approved by the right governing body (I forget the acronym for the fuel one), and wasn't Billy Bob's Backyard snake oil in a can, I don't think the manufacturer can have an issue about it.
  5. Freespool
    Freespool New Member
    Kemah, Texas
    Many of the common rail injectors do not tolerate additives. The molecules are larger than diesel fuel. Also any additive that "eliminates water" normally has a binding agent that lets the water pass to the engine past the racors. Water molecules do not compress. Pulling fuel, oil, and coolant samples is standard practice with a major warranty claim these days. A fuel sample is required for most major fuel system related claims.
    Of course a high pressure pump and 16 injectors on a 2400 horsepower engine runs about $40,000.
    Just my $0.02 worth.
  6. Old Phart
    Old Phart Senior Member
    I dunno
    Anyone try Stanadyne or Power Service?
  7. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    I am pretty positive that most if not all engine manufactureres will have some sort of document that specifically details what is an approved Fluid (fuel/additive/coolant/cleaning agent) or Lubricant (oil), within the engine manufacturer's specifications, regardless of any governing body.
    If it is not it the document, DO NOT put it in your engine until the warranty period expires, you will typically have no basis for a warranty claim thst can be attributed to the non-approved offendor. :(
    After the Warranty Period, it is a wide open ball game, and will be up to your own discretion if you stick "by the book" or search other ingredients for your engine to "digest". ;)
    I have used the power service products and swear by them. The clear tank diesel product disintigrates the algae.
  9. Marmot
    Back to the topic ... has anyone been told by a technician or dealer that using an additive will void the warranty?
  10. Duke
    Duke New Member
    Boston
    Algae does not grow in diesel fuel. Now back to the original topic.
    Duke
  11. Beau
    Beau Senior Member
    Beaufort, NC
    Duke
    Algae grows in the water that sits under the diesel fuel that sits in the tank....not nice to your racors.
  12. rgsuspsa
    rgsuspsa Member
    Melbourne, FL
    What Grows In Fuel Tanks
    What grows in fuel tanks is not algae, which requires light for photosynthesis.
    Molds and fungi are the substances which grow in fuel tanks. They are mistakenly referred to as algae.
  13. Beau
    Beau Senior Member
    Beaufort, NC
    Ron
    Won't quibble with that. Biocides are a major category of additives to diesel fuel. It s a shame if they void your warranty because they are sometimes necessary even with high fuel turn over. Those magnet things haven't convinced me they are a real alternative. BTW, good to hear your voice over here.
  14. Capt J
    The Algae-x's are on one of the yachts I manage and maintain. They do a great job macerating the algae so that they pass right through the 10 micron primaries and clog up the 2 micron secondaries. If the boat didn't have metric fuel fittings I'd have to convert, I'd yank them off in a heartbeat.
  15. Beau
    Beau Senior Member
    Beaufort, NC
    CaptJ
    So based on your experience, the maganets are too efficient? Have you ever heard that accepted additives can void your warrantty??
  16. RT46
    RT46 Senior Member
    funny but my filters only seem to clog when i put additives in the tank.
    I have dual racors and seem to do best with 10 microns on the first filter and 30 on the second....
    when and if the 10 micron cloggs without notice i switch over to the 30 micron element and change and clean the 10 micron side asap.
    this set up seems to keem my detroits happy and the primary and secondary on the engies clean and clear.
    whenever my vaccume gague starts to show more that 6-10 i change the filter.
    Like I said, i always seem to get more gunk in the filters when I use DK, i assume it is the gunk breaking up in the tank from the DK.
    I do not use those magnets in the fuel, some of my friends swear by them and say it cuts down on the smoke also....
  17. PacBlue
    Dana Point, Ca
    I am not sure if I follow the logic of having the finer mesh (10 micron) filter before the larger mesh (30 micron) filter on the dual Racor. You are now passing through larger elements to your on engine filters, which increases the risk of clogging?
    Why not just have both at 10 micron?
  18. Marmot
    OK, so where do these larger elements come from? Is the outlet of the 10 micron filter disintegrating or something?
    I agree it is silly to put a 10 before a 30 but a lot of what boat drivers do to their machinery is pretty silly.
    Most engine manufacturers tell the operator what micron size filter to install or use for a replacement element but hey, what do they know?
  19. PacBlue
    Dana Point, Ca
    I am assuming the 10 micron would be shut-off when the vacuum gauge hits the 6 - 10 range, and then they would be running on the 30 micron for however long, until the replacement of the dirty 10? Also. some fuel additives can attack the Racor element and render the micron rating useless. So not only do you need to be aware of the engine manufacture's approved Fuel Additives, but also the Fuel Filters' approved list - seems like a lot of trial and error for the boat operator.
    I would still expect the filter progression to be something like 30-10-5-2?
  20. travler
    travler Senior Member
    roche harbor wa
    MARMOT
    i haven't figured out a lot of boat drivers yet and don't even try any more some things just don't make sence to me but i am old and dumb
    travler
