Click for Burger Click for Mag Bay Click for Mulder Click for Furuno Click for Cross
Rudder packing "rings"? - Viking motor yacht
Discussion in 'Technical Discussion' started by captainwjm, Nov 29, 2012.
  1. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    89 55´ Viking Motoryacht
    I have a question concerning my ´89 55´ Viking Motoryacht.On the rudder shaft the packing in the packing gland appears to be a solid ring instead of a wrap like on the prop shafts. Is this right? and if so, can I cut it off and replace with wrap, or do I have to get replacement solid rings [and would this require blocking the rudder from below the hull and a removal of all support of the shaft to slip the rings on?]?
    Thanks,
    Bill
    Nashville, TN
    Solid rings made of plastic? Flax rings? or "O" rings? Also, are these rings above the water line?
  3. captainwjm
    As best as I can tell, the rings are fiber, but not like a flax. More like the rings you place under a battery cable terminal, but about a quarter inch thick. There are two of them, and they are saturated with water [yes, they are below the water line]. The rings are solid, in the sense that they are a "ring" and not a loop of packing material.
    The two rings are stacked on top of a plate, and are pressed down by another plate that bolts to the bottom plate. The top plate has a cone into which the two rings fit. To improvise, we added a strip of flax above the two rings and screwed the top plate down tight - which reduced the water flow to a seepage.
    Viking has no information on these older boats, and no source for these rings. What I'd like to do is remove the rings and use regular graphite packing as I do on my shafts - but I'm hesitant to remove the rings without more information.
    Thanks for any assistance.
    Wow, That sounds kinda cool. Shame it's not working.
    Always heard that Viking was great at answering questions on the oldies.
    Any brand or casting icons on the equipment? maybe a pic or two?
  5. dsharp
    dsharp Senior Member
    lake jackson, tx
  6. captainwjm
    I'll try to get some photos this weekend. No casting icons seen.
    Thanks for the catalog; I don't see any rings in the steering section, but I'll contact them after I get the pics.
    We did unbolt the collar, and saw nothing under the collar except the rings. According to the original owner's manual [not detailed at all], there is a fiberglass bushing that surrounds the rudder post extending from the lower plate through the hull. As far as we could tell, that is intact.
    FWIW, there was never a large volumne of water, even when we slipped the rings upwards [although the volumne increased when we did]. After the procedure I described above, the water flow slowed to seepage. The other rudder post has no seepage at all, so I still have work to do.
    Thanks for all the assistance.
  7. Pascal
    I believe these MYs were built for viking by the Lazara family back in the Gulfstar days, weren't they? They may be the folks to ask..
  8. captainwjm
    Pascal, that's a good thought; thanks. FYI; Viking didn't have any information for me, but they're waiting for pictures, too.
  9. Marmot
    There aren't any pictures in that post, just a link to some site that you have to subscribe to in order to see some pictures ... maybe.
    Why not just post the d**n pictures and cut out the middleman?
  10. captainwjm
    Ok, Ok; so my mechaical skills don't translate to the electric computer!
  11. Marmot
    Those photos and the drawing are not the same item.
    The upper ring with the square headed set screw looks like a low-rent shaft collar type of retainer and thrust bearing more than a "packing gland" as there does not appear to be any means to tighten the "gland" and compress packing against the shaft.
    Does the lower ring with the 4 bolts rotate with the rudder stock or is it fixed to the plate with the countersunk fasteners?
  12. captainwjm
    Actually the drawing is pretty close, just not detailed. The top is a retainng collar. Under the retaining collar is the packing gland that bolts to the sole; inside that packing gland are the two fiber rings that I inquired about. We lifted both the retaining collar and the packing gland to expose the fiber rings [we blocked up the rudder using a jack and the tiller arm]. Since we couldn't remove the fiber rings, we added a layer of packing gland material above the fiber rings - inside the packing gland - and bolted it back down again, which lessened the seepage - so we're on the right track. So the question is, do I need to replace the fiber rings, remove the rings and replace with regular packing gland material, or add more packing gland material on top of the existing rings?
  13. dsharp
    lake jackson, tx
    I've spent about 40 years around boats and I have never seen anything like that. The drawing appears to show a regular gland nut with the packing inside the nut that compresses when you tighten it. I think your biggest problem is finding the rings. I can't see how a conventional packing material that is wrapped around the shaft is going to last for any length of time. Is that the bottom of the hull in the picture or is the hull built up around the rudder shafts where the plate is fastened to?
  14. Marmot
    Those four bolts appear to be very close to the shaft/stock so how can the packing compress against the shaft if there are bolts in the way?
    The packing has to seal both the shaft/stock and the face of the plate to which it bolts. It would take something like an O-ring seal between the shaft and the "gland" plus another mounted between the gland and the plate to which it is bolted in order to seal the shaft. If you just seal the face of that gland to the plate there is nothing sealing the shaft.
    Look at a drawing of a conventional shaft packing gland and you will see what I mean. What you describe is only half a seal.
  15. Pascal
    So the 4 bolts compress that plate which in turn compress the rings against the shaft and housing?
    If that s the case the you could replace the rings with conventional packing material...
    I wonder about the safety wire on that bolt... Why is that collar so critical to require a safety wire if the compression and sealing is done with the 4 bolts.
    It does say Gulfstar on the drawing :). I d still call Lazzara, someone may remember the old days!
  16. captainwjm
    Pascal, I think you have described it correctly and answered Marmont's question: "So the 4 bolts compress that plate which in turn compress the rings against the shaft and housing."
    I have sent an inquiry to Lazzara and will post its response.
    Dsharp, that's the bottom of the hull.
    As to Pascal's question: "I wonder about the safety wire on that bolt... Why is that collar so critical to require a safety wire if the compression and sealing is done with the 4 bolts." It appears that that collar is only to secure the rudder if the tiller arm needed to be removed. Viking says that if it and the tiller arm are removed [which would be the case if I had rings to replace] the rudder would need to be blocked from below. As it is, there are dimples on the shaft corresponding to the bolts in the collar that are safety wired. So, it dosen't appear to be a critical piece, but a redundant one to keep the rudder from falling out.
    Thanks to all for your assistance on this one. As Dsharp says: I've spent about 40 years around boats and I have never seen anything like that.
  17. captainwjm
    Rec'd the following information from Viking:
    It sounds like you want to repack the rudder seals. The rudder must be supported from the out side, the rudder collar (collar with the bolt and lock wire) must be lifted up and off of the ring underneath it. The ring with the hex head bolts must be lifted up and under that ring is where he will find the packing, or what is left of it. Don’t mess with the straight slot bolts at all.
    The packing goes between the ring that has the four hex head bolts in it and the plate that has the straight slot bolts. I have no idea where the fiber rings came from. I would go with removing the fiber rings and replacing with fiber packing being sure to stagger the joints where the ends meet.
    Nothing recieved yet from Lazzara.
  18. Marmot
    I don't see any need to support the rudder from outside, just tie the tiller arm to something that will take the weight and prevent the thing from falling out of the boat. It looks like there is plenty of room to lift the collar and "gland" to replace the packing.
    If you plan to do this very often, drill and tap the top of the stock (shaft) and put a ring bolt in for lifting/holding purposes.
  19. captainwjm
    Marmot, that's exactly what we did. We used a screw-type car jack to support the tiller arm and had about 3 inches of space to work with after we lifted the collar and "gland." Since we were unsure about removing the solid rings we just added a layer of regular packing above it to give the "gland" something additional to press agaisnt. As I mentioned before, that slowed the seepage, so now we know what to do going forward.
    Thanks for the assistance.
