Click for Burger Click for Westport Click for Ocean Alexander Privacy Matters Click for Cross
Transmission problem
Discussion in 'Technical Discussion' started by alexm, Jul 23, 2012.
  1. alexm
    alexm New Member
    Black sea
    After hitting a rock, damaged struts, shafts and props.
    Everything has been changed for a new ones. What would be a symptom of coupler/transmission damage?
    How can one distinguish between the misalignment of the shafts and coupler/transmission damage?
  2. Marmot
    Misalignment can lead to coupling/transmisson damage.
    If you are afloat, unbolt the shaft coupling and check the alignment with the boat loaded the way it normally runs.
    Check the gearbox oil screen for wear metal and have a look at the oil. If the oil looks good have it tested.
    What symptoms are you having that lead to this question?
  3. alexm
    alexm New Member
    Black sea
    My shop replaced the running gear, then they take the boat for a sea trial and decided that probably there is a coupler or transmission problem- they could hear some noise, which appear while they were going, forward and reverse.
    They did not do realignment. The oil looked OK.
    Just wondering, how can they say this is not a misalingment but rather coupler/ transmission issue?
    They claim that they have to remove transmission and disassemble it in order to find what is damaged.
    Does it sound reasonable?
  4. Pascal
    "They claim that they have to remove transmission and disassemble it in order to find what is damaged. Does it sound reasonable?"
    Do you really expect a reply when you don't even say what kind of boat, tranny, etc you have??
  5. alexm
    alexm New Member
    Black sea
    It's a Carver 41 CMY with Volvo Penta D6 - 370 HP
  6. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    Well the first thing I have seen with shafts/struts/running gear alignment issues is a bad vibration.
    You mentioned that they said "they heard some noise". This needs to be explaned better by them. Was it a noise coming from the transmission or was it a noise from rattling/bumping/shaking from everywhere else.
    If a transmission in making a noise, it's fairly easy to distinguish over other noises.
  7. Marmot
    Was there any rudder damage? Was the rudder bearing distorted? That can be a source of noise and vibration that appears to come from the drive train.
  8. alexm
    alexm New Member
    Black sea
    Yes there was a rudder damage, rudder bearing was distorted and then fixed.
  9. dsharp
    dsharp Senior Member
    lake jackson, tx
    If you hit something hard enough to bend the rudders, shafts and struts it very likely tore up the drive plate between the flywheel and the reduction gear. Did you continue to run the boat after you hit the rock or was it towed? I don't know how they could replace the running gear without lining it all up. Why do you think it's an alignment problem?
  10. Gannet
    Gannet New Member
    Baltimore, Maryland
    Sounds like it maybe the motor mounts saw too much shear loading.
