Click for Cape Scott
Click for Nordhavn
Click for Horizon
Click for Lurssen
Click for Christensen
Click for McKinna
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Corrosion Prevention- Thru Hulls
Reply
Old 05-19-2012, 08:52 PM   #1 (permalink)
Registered User
I need to go through my bilge and take care of the bronze thru-hulls. Some are developing the nice blue stuff-corrosion. Does Corrosion Block work as a long term preventative? Any recommendations if not?
crackerD is offline   Reply With Quote
Old 05-20-2012, 08:38 AM   #2 (permalink)
Senior Member
Check your bonding, if it's good, just use vinegar and a wire brush on the heaviest corrosion. That green coating that forms on bronze is the metals way of protecting it's self from further corrosion so I wouldn't work to hard to remove it.
Capt Bill11 is online now   Reply With Quote
Old 05-21-2012, 08:54 AM   #3 (permalink)
Senior Member
C4ENG's Avatar
Quote:
Check for dissimilar metals in your plumbing that are not isolated. If you see corrosion around the threads then I would be kind of concerned and spraying lubricants on it will do next to nothing for you.
Corrosion Block, great stuff BTW, is not a long term corrosion preventative especially for plumbing. There are other products for that.
One product (I can not remember the name of) is like a greased cloth that that you wrap around the plumbing fittings and it allows no moisture in. I see it used a lot on jet drive vessels with hydraulic hoses and fittings near the water line.
C4ENG is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 05:53 PM.
Click for McConaghy
Click for Alexseal
Click for McConaghy
Click for JetForums
Click for Dockwise
