Privacy Matters Click for Abeking Click for Walker Click for Nordhavn Click for Ocean Alexander
Rudder Alignment
Discussion in 'Cabo Yacht' started by CSkipR, Apr 22, 2012.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Can someone interpret this pdf file on the correct rudder alignment for my boat and explain in layman terms how I measure?
  2. CSkipR
    CSkipR Member
    Okay I think I figured it out. The trailing edge of the rudders (closest to stern) should be 2.5" further apart than the rudder leading edge (bow) according to the spec sheet.
  3. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    I did not look at the file yet. But that sounds right. They want some "toe in" on the rudders.
    Yes, that is how your boat is setup from the factory.
  5. curtarmy
    curtarmy New Member
    Grand Haven, MI
    Maybe stated somewhat differently...... If you have the Wedge type rudders, the inside surfaces should be parallel, that is... the same distance (dimension) between the inside surfaces as measured near the forward edge, at the rudder post, and near the aft edge.
    If you have the Plate type rudders, the inside surfaces measured near the aft edge should be 2 1/2 inches more than the distance of the inside surfaces at the rudder post (note: not the forward edge).
  6. CSkipR
    CSkipR Member
    Curtarmy,
    Absolutely correct as I learned. I have the plate rudders. Thanks
  7. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    I disagree- the rudders should be 2 1/2 inches further apart at the center of trailing edge than at the center of the rudder posts- NOT the inside edge to inside edge or outside edge to outside edge.
