Click for Northern Lights Click for Ocean Alexander Click for Walker Click for Abeking Click for Westport
Vetus Hydraulic Steering
Discussion in 'Technical Discussion' started by Wireless, Apr 13, 2012.
  1. Wireless
    Wireless Senior Member
    USVI
    My vessel has a dual station Vetus Hydraulic steering system with manual pumps. For sometime there has been a "chatter" when reversing direction at the helm. The fluid in the helm reservoirs are kept at the proper levels. I had the cylinder rebuilt and rechromed in December. A new bypass loop was installed and I had a professional purge the system again just to be sure that I was not missing something in my many attempts to remove trapped air. I removed one pump and had it rebuilt. The inside station's pump will be a bare to remove so I deferred its rebuilding to see if there was any improvement in the outside station.
    There was no noticeable improvement in the feel of the helm.
    Any suggestions? Would it be necessary to have both helm pumps serviced if they run independently?
    When you hear this chatter, do you feel it at either station? Is the rudder in deed turning, AND, is the chatter coming from the stearn or helm?
    Need more input Dr. Smith...
  3. Wireless
    USVI
    Thanks for your interest in helping.
    The "chatter" is felt, not heard. Whenever either helm is turned it does in fact turn the rudder. Once the direction of the helm is reversed, there is a sort of skipping sensation before the rudder follows. The helm then feels normal until the direction changes again. This sensation happens every time at both stations. Steering a sailboat with Hydraulic steering is a lifeless sensation at the best of times but with the current situation it is down right unpleasant.
    And it happens dockside? and/or underway?
    I think it's the rudder post binding. You may have already tried, disconnect the rudder from the cylinder.
    Another more interesting step, if you have an emergency tiller, mount that and try to feel the chatter with / without the cylinder attached.
  5. Capt Ralph
    Oh, just thought about it,, Do you have a pilot pump Td into the system somewhere?
  6. Wireless
    USVI
    We had the rudder out last week to pull the shaft and replace VPP components. With everything disassembled the rudder turned relatively freely. I say relatively because its big and heavy.
    We are now back afloat.
    The chatter happens when you reverse direction regardless of how far off center the rudder is.
    There is a pilot. It is tee'd into the system a couple feet from the cylinder.
    The plumbing is copper except for a very limited amount of rubber hose near the cylinder.
    New packing in the stuffing box, quite loose at present since we are still re-commissioning and haven't got to tightening it up yet.
    thanks for the input,
  7. Capt Ralph
    Does the system make noise while running on the pilot?
    If it's not the rudder post, then it's a check valve somewhere.
    New sound or always been there. If it's new, work back-wards and un-do what was done... Yea, easy for me to say....
    Not induced, check valve somewhere.
    Always been there? Makes noise in both directions? restriction in the return line somewhere.
    With out hands on, that's it for me. Look forward to hear what you find. Maybe another member here will pick up.
    OR
    O K, you have to fly me down so I can fix it fer ya. I may have to suffer and work some over time. Should have it fixed in a few weeks. Maybe a lil longer but for sure before years end.
  8. sunchaserv
    sunchaserv Member
    Carefree, AZ
    A few other thoughts from tomg - "dirty" oil, rubber hose coming apart inside with debris blocking system?
  9. Wireless
    USVI
    I really appreciate what is obviously a considered opinion. We will be doing seatrials on the VPP first of the week. I'll be listening to the pilot closely then.
    I believe the check valves are in the Vetus helm pumps? I was told that the valves needed work in the pump that was serviced. I am wondering if my continued problem comes from not servicing the second pump at the same time?
  10. Wireless
    USVI
    Did not change the oil. Only added what was lost in removing the cylinder etc. The tech did say that the oil in the pump was "a little dirty".
    Only a limited amount of rubber hose. Maybe 24" total but likely twenty years old.
  11. Capt Ralph
    Yep, The old hose idea is a very good one. Had a fuel hose do some internal scaling and gave me a headache. Sorry I didn't think about that.
    You may have to fly two of us in,,,,,
  12. Wireless
    USVI
    not sure what the budget is for flying people in, but after the cost of re-chroming the cylinder, replacing the seals, hiring someone to do exactly the same things I did to purge the system, installing a bypass loop, replacing the packing with teflon, and removing and rebuilding one of the helm pumps, if I don't see a noticable improvement soon the budget is likely to include flying me out.
    keep a watch on the job vacancies postings, I suspect I'm skating on thin ice...
  13. Capt Ralph
    That may mean we travel the old fashioned way:
    BACKSTROKE...
    Good luck,
  14. garyohv
    garyohv New Member
    Florida & Oregon
    When you change steering direction the Non Return Valve moves to redirect the fluid. Where are yours, external or internal? The mechanic said the check valve needed rebuilding so they must be internal (?). Replace the other NRV O rings. They are inside the big cap.
  15. Wireless
    USVI
    Recap
    To recap,
    So far I have,
    Had the cylinder re-chromed
    Had the seals in the cylinder replaced,
    Had the Vetus manual hydraulic helm pum serviced including grinding the seats in the check valves
    replaced any rubber hoses
    Purged the system,
    Had the system purged by someone else
    Re-purged the system
    drained all the old fluid
    repurged the system
    installed a bypass loop at the cylinder and repurged the system
    removed the ruddre and changed the bottom bearing and repacked the stuffing box with teflon,
    and,
    I get two annoying "skips" in the helm everytime I reverse direction regardless of what angle the rudder is at when I change direction.
    Can hear the "skipping" in the lazerette. Can not hear anything unusual over the sound of the autopilot's motor so not sure if it happens then or not.
    Absolutely no air at bleeders on cylinder, pump full, autopilot res. full. Fluid clean, new HY-32.
    Frustrated to say the least.
  16. garyohv
    garyohv New Member
    Florida & Oregon
  17. Wireless
    USVI
    thank you "Gary?" for your reply. I'm going to take some more time to review the drawings but wanted to thank you for your interest and help right away.
    Unfortunately my German is weak and the drawings do not illustrate the particular Vetus pumps I have. I do have the drawings and model numbers etc but can not share them now as I am only barely computer literate.
    I can say that the non return valves are integral and that there are no adjustment points or check valves external to the pump.
    I saw the pump in its disassembled state and the only operator service point is the top of the reservoir.
  18. garyohv
    garyohv New Member
    Florida & Oregon
    Try: http://www.datahidrolik.com/EN-En/our-product/23/Hydraulic Steering Systems.asp or use just the name.com and go to Downloads.
    Draw your system.
    1. Which autopilot? Does it have NRV? Isolate it from the system and test.
    2. When turning a helm pump, it first selects a port to feed, and second, as fluid enters the NRV, opens both the feed and return ports. It has a O ringed piston inside sliding to open ports. It seems your pump/porting is slow to pressurize...sugesting, besides air, a leaking valve, piston, or port.
    3. If both pumps "slip" one might assume it's not the pumps, but it could be one affecting both. Strange, but the 2 pump diagrams show the ball in the NRVs in a different position....one is wrong.
    4. Something simple could be the problem...such as the cly. mount plate bolts.
    Cap off auto pilot first (at the T fitting). Then a helm pump. Test one pump or section at a time.
  19. Wireless
    USVI
    nrv
    Thank you Garyohv for your comments. they inspired me to keep searching. buried in the darkness behing the pilothouse icemakers I found a dual station non return valve along with the helm pressure equalization line. Sounds like this is the most likely culprit so its coming out today bound for the repair shop. A messy proposition given that its barely reachable but if its the problem then its worth the effort.
  20. garyohv
    garyohv New Member
    Florida & Oregon
    If you are going to remove the NRV without draining, seal the upper vent cap or replace it with an unvented cap to slow the drain rate.
    The only part to replace inside is an O ring.
