Click for Walker Click for Nordhavn Click for Burger Click for Abeking Click for Delta
Hullboard for Trawler Engine Room
Discussion in 'Technical Discussion' started by dsharp, Apr 10, 2012.
  1. dsharp
    dsharp Senior Member
    lake jackson, tx
    http://www.yachtforums.com/forums/bering-yachts/15138-review-bering-yachts-55-steel-trawler-2.html Is anyone familiar with or have any recommendations for material to use to put over the soundproofing in the engine room bulkheads/salon floor of a small fiberglass trawler. The material in the photo looks to be a tempered pegboard. I am looking for a material that will hold fasteners well and offer some protection against engine room fires. I haven't built/re-built any boats in the past 15 years and I am curious to see if there has been any improvements in the available materials. Weight is not a big consideration, but I would like to be able to surface-fasten wire looms and copper tubing straps for plumbing and steering systems. Has anyone seen any cable trays that stood out in their mind and made a neat installation? The vessel in particular is a 40' fiberglass trawler style that is being rebuilt. Apparently, the last owners idea of wiring was running extension cords and wire nuts. Thank you.
  2. jeffreybblake
    jeffreybblake New Member
    Lake Norman
    I can assist with the insulation if that is of concern or you have any questions. Most of the applications I have seen use a coated/painted perforated metal sheathing over the insulation. Sometimes the insulation itself has a perforated fiberglass cloth adhered to it, but I am not certain I would fasten anything of weight to it.
  3. PropBet
    PropBet Senior Member
    Is Everything!
    So we're not rehashing or trying to re-engineer something, the description of the subject is pretty explanatory.
  4. JWY
    JWY Senior Member
