Click for Cross Click for Nordhavn Click for Walker Click for Westport Click for Burger
Zincs vs. Magnesiums
Discussion in 'Technical Discussion' started by Celtic Knot, Apr 1, 2012.
  1. Celtic Knot
    Celtic Knot New Member
    Catawba Island
    I was working on my boat yesterday getting it ready for Spring launch. A mechanic stopped by to chat and told me that i should have magnesum blocks in place of my zincs. He said that the zincs don't really do anything as I am in fresh water, that they should be replaced with magnesums?
    Does this make sense? or he just trying to sell me?
    He's right.
  3. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    On the galvanic chart series, magnesium is least nobble from Zinc which means the magnesium will then sacrifice itself to protect any zinc installed on the vessel making the zinc a more noble metal in that situation.
    Fresh water does carry less TDS to carry electric currents and atoms to flow through but I would be interested to know why or how magnesium could sacrifice itself better than zinc to preserve the more noble metals just because it is in fresh water oppose to salt water.
  4. NYCAP123
  5. K1W1
    If you can overcome the sales pitch there is some good info to be found here.
    Cathodic Protection - Marine Cathodic Protection - MGDUFF
  6. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    K1
    I found the answer as to why mag would be better than zinc in fresh water in the link you sent. I cut and pasted for others to see......
    Not all anodes are suitable for every environment, for example the surface of a zinc or aluminium anode will if left in fresh water for some time become covered with an off white crust of oxide which effectively seals the anode and stops it working even when returned to salt water.
  7. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
