Click for Oceanco
Click for Dockwise
Click for Garcia
Click for McKinna
Click for Westport
Click for DeAngelo
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Eng Fuel Filters Man CR900
Reply
Old 03-24-2012, 10:19 PM   #16 (permalink)
Registered User
Yes mine are 6 cyl.
I think air is more of a problem with common rail engines because of the higher pressures in the fuel system.
My personal boat has cat 3208's. Like most older engines if they get air bound you can crack the fuel fittings where the lines go into the injectors, then crank the engine until fuel runs out of the tubing. Re-tighten them and start the engine.
This should NEVER be done with common rail engines because the pressure in these lines is much higher and can cause serious injury.
captjohn22 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 03:06 PM.
Click for Ferretti
Click for Cheoy Lee
Click for Burger
Click for Moonen
Click for Cape Scott
Click for Walker
