Click for Northern Lights Click for Mulder Click for Furuno Click for Ocean Alexander Click for Mulder
What is this?
Discussion in 'Technical Discussion' started by tirekicker11, Oct 27, 2011.
  1. tirekicker11
    tirekicker11 Senior Member
    SE Asia
    Spotted these props on a twin prop cruiser yesterday. The props seem to have some sort of anti-singing strip attached to them. Can anyone tell what they actually are?
  2. RT46
    RT46 Senior Member
    Are those Flux-Capactiors?
  3. tirekicker11
    SE Asia
    It's a boat, not a DeLorean.
  4. Bill106
    Bill106 Senior Member
    Beaufort NC
    Veem Interceptors
    Those are Veem Interceptor wheels and those strips are changable with different thicknesses to fine tune pitch/cup in small increments without having to rebend the wheel. Veem uses this on many production boat wheels to adjust for varying boat weights due to diferent options selected and by using a "one size fits all" base prop, can tune each boat with minimal rework.
  5. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    +1 to what Bill106 posted.
  6. PropBet
    PropBet Senior Member
    Is Everything!
    Yeah. What Bill106 said...... :eek:
  7. tirekicker11
    SE Asia
    Thanks Bill106!
    No mention in Gerr's book about them...
    Very neat, I've dealt with quite a few sets of Veems, but not so much in the last 2 years......What are the strips made of, are they a permanent solution, and do they just slide into a track that's already in the propellor?
  9. Bill106
    Beaufort NC
    The strips are made of some type of slippery polymer material that seems to resist fouling pretty well. They are slotted into the groove in the blade face from the inside out to keep them from slinging out but we have hauled and found them missing on occasion.
    While they do give you a full range of adjustment it's only as much as you would get with cup, from none to full about an inch and a half of pitch. They use it pretty successfully on Vikings and Hatts to adjust for different options and/or moving south into warmer water from colder northern climes. Some people also change them when travelling heavily loaded for long trips. I've used them with even better results to dial in a new boat and then order a set of their Sportfish series which seem to have less slip than an Interceptor. Much easier than banging a new set several times and Veem can translate better from a set of their own than a set of "cheaper" other brand wheels.
  10. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    If you're at FLIBS, go see the the Veem/General Propeller booth. Joel showed me a prop with the interceptor. If going with this option, it has to be designed into a new boat or replacement prop as there is a groove that the interceptor rides in. They are not glued onto the surface.
    If you need the options of different prop cupping as mentioned before, this seems like a viable option. Just don't hit bottom as they probably won't survive a kiss to a rock or sandbar (but then again, neither will the prop).
  11. SeaEric
    SeaEric YF Historian
    out on the dock
    Hardly a day goes by when I don't learn something all together new from visiting YF. Cool.
  12. Capt J
    They are nice......but if you REALLY want to see nice props check out Rolla's.......
  13. HTMO9
    HTMO9 Senior Member
    Humphree Interceptors
    My son asked me today about Humphree Interceptor Stabilization Systems for his planning boat. I had no clue. His boatbuilder asked him, whether he wants them additionally ??????
    Never heart of them and their website does not work for me. Has anybody in the forum any practical knowledge of or about them? Are they still in business? How do they work and how good are they?
    Many thanks in advance.
  14. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    I believe the Humphree's product are vertical trim tabs that can control pitch/roll. Not to be confused with Veem Interceptor propellors.
    Never used them but I suspect the Volvo Penta Interceptor Trim Tab design came from them in some sort of royalty agreement.
  15. HTMO9
    HTMO9 Senior Member
    That would explain the request of the boatyard. The boat is to be equipped with 4 x Volvo Penta IPS 900. He wants to add a genuine Volvo Penta trim system, which than works together with the IPS computer and the special Raymarine IPS autopilot.
    I had just typed in: Interceptor Trim System and Humphree came up. I have never seen this Volvo Penta or the Humphree system before. I hope it works.
    Thanks a lot
  16. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    The Volvo system is fine and works very well with IPS. The only thing to watch is that they must be fitted to a completely flat surface, no curves on the hull.
