Click for Nordhavn
Click for Oceanco
Click for Lurssen
Click for Cape Scott
Click for Ferretti
Click for McKinna
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > What is this???
Reply
What is this???
Old 06-30-2011, 07:18 AM   #1 (permalink)
Registered User
PhilG57's Avatar
What is this???
These two units are in the electronics closet on my sailboat. At one time, they may have been used for electronic noise suppression, but now I have no idea if they are needed. Can anyone confirm their function??? Thanks.
PhilG57 is offline   Reply With Quote
Old 06-30-2011, 09:10 AM   #2 (permalink)
Senior Member
Marmot's Avatar
Quote:
Remove one and read the label.
Marmot is online now   Reply With Quote
Old 06-30-2011, 11:19 AM   #3 (permalink)
Senior Member
PropBet's Avatar
^that^
It looks like a power inverter possible, but a couple of screws and a look on the back will tell you everything you need to know.
What mfg of boat? What / where do wires go to and from? They don't appear to be connected now? (or at least from the limited view in your image posted.)
PropBet is offline   Reply With Quote
Old 06-30-2011, 06:45 PM   #4 (permalink)
Senior Member
Fireman431's Avatar
Single wire in with a 12v + & -? An alarm possibly? Is that a peizo alarm on the top of each?
Fireman431 is offline   Reply With Quote
Old 07-01-2011, 07:45 AM   #5 (permalink)
Senior Member
Marmot's Avatar
Quote:
It is a power transistor and that points toward the item being a power supply or regulator of some sort.
Old 07-01-2011, 08:16 AM   #6 (permalink)
Registered User
PhilG57's Avatar
All good ideas - thanks. I'll try to take a closer look at the units this weekend, as my desire is to remove them if no longer needed. Boat is a Swan 57 sloop. Thanks again.
Old 07-15-2011, 07:14 AM   #7 (permalink)
Registered User
PhilG57's Avatar
The units have labels which read something like this:
Blaupunkt
Elektronischar
Sbgunugstailer
If I Google that last word, it suggests "Spannungsteiler" which turns out to be some sort of voltage divider.
I also discovered that if I pull off the ground wire from the units, the (new) VHF radio will not power on so I assume these units are in the electrical return path for some reason.
Think this is going to wind up being another electrical mystery to me.
Thanks.
Old 07-15-2011, 08:12 AM   #8 (permalink)
Senior Member
Could they have been amps for an old stereo system?
Capt Bill11 is online now   Reply With Quote
Old 07-15-2011, 09:02 AM   #9 (permalink)
Senior Member
Marmot's Avatar
Do you have a 24V boat? Or a 12V boat with a 24V radio?
Old 07-18-2011, 07:02 AM   #10 (permalink)
Registered User
PhilG57's Avatar
She is a 24v boat, with a couple or 12v circuits for electronics. I believe this is a 12v circuit as the old Sailor VHF radio had it own, dedicated, 24v to 12v converter.
Old 07-18-2011, 08:29 AM   #11 (permalink)
Senior Member
Marmot's Avatar
There you go then. Disconnect them and all the 12V electronics will probably go dark.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 05:12 PM.
Click for Lurssen
Click for Dockwise
Click for GPlink
Click for Trinity
Click for Westport
Click for Delta
