Click for YF Listing Service Click for Delta Click for Cross Click for Westport Click for Burger
Californian 53' Aluminum fuel tank question
Discussion in 'Technical Discussion' started by plpmusic, Apr 25, 2011.
  1. plpmusic
    plpmusic New Member
    baldwin harbor NY / Little River SC
    I am considering the purchase of a 53 Californian. It is 25 years old. There are 3 Fuel tanks and are all aluminum and buried and wonder if at some point in time I may need to change them, how difficult and what expenses of getting them in/out am I looking at? Anyone out there familiar with the build and mechanical layout of this boat or have to address this in this issue before?
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Changing out fuel tanks can be very expensive and be a major PITA. It often involves cutting the boat open on the sides or bottom. Or removing the engine/s.
    If the tanks are suspect you need to try and get a look at as much of them as you can. Using mirrors and fiber-optic cameras. See if it looks like the tanks are or have been getting wet down near there bottoms or lower sides. You can have them pressure tested but that only tells you they are good on that day.
  3. plpmusic
    plpmusic New Member
    Californian 48-53-55- fuel tank re-placement
    thanks Capt. Anyone familiar with construction of the Californian and how these tanks may have been installed? If i need to have a tank replaced, I'd like to know what method would be least expensive...Before- I invest in purchase of this vessel, so I can incorporate a 'worst case scenario'
