Click for Nordhavn Click for Nordhavn Click for Delta Click for Perko Click for Burger
detroit diesel 8v92 oil
Discussion in 'Engines' started by ArielM, Feb 8, 2011.
  1. ArielM
    ArielM Senior Member
    Los Angeles
    How much oil (in galllons) does a detroit 8v92ta engine take?
    I think around 8-9 gallons per engine. But cannot remember for certain, any DD dealer should be able to tell you.
  3. RER
    RER Senior Member
    Newport Beach CA
    Approx 6 gallons. Depends how much old oil is left behind and where your filters are located and what size(s) they are.
  4. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    According to the DDC book, total capacity on a 8V-92 TA 735 BHP marine engine is 27.5 quarts with filter.
    At a zero-degree installation angle, less filter, High is 25.4 qts. and Low is 18.5 qts.
    Max installation angle is 15 deg. Oil flow is 39 gal. per min.
    Did I win the toaster?
  5. Pascal
    speaking of oil and DDs, many yards still use Delo 400 in those which has been reformualted aroudn 2003 and is no longer "approved" for use in 53, 71 and 92 series detroits. if using chevron, you need Delo 100 (straight 40), not 400!
    7 years after Chevron/DD issued a service bulletin on this issue, i still see it happening!
