Click for Mag Bay Click for Perko Click for Nordhavn Click for JetForums Click for Westport
removing a washer & dryer
Discussion in 'Technical Discussion' started by jterry, Jul 28, 2010.
  1. jterry
    jterry New Member
    SNEAD ISLAND, (PALMETTO) FL.
    Has any one ever removed a washer dryer from a 1988 45 Viking with a C floor plan. If you have how did you get them out?
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Drive up the road to Marlow's place and ask for George Dragon. There is not much George hasn't done on a boat. If he doesn't know off hand, I'll bet he can figure it out right quick.
  3. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    jterry:
    No, I have never replaced a washer/dryer from a 45 Vik, but I have listed and sold a few of these, particularly the Plan C, which seems to be the more popular model, and paid attention to details like this.
    You might have to remove the doors--and should so you don't prang the joinery as you wrestle the bear. Pull it straight out, then angle it around/over the dinette table, up past the galley and out the salon door.
    Viking did NOT install the washer dryer and then build the rest of the boat around it--nobody's that good.
  4. Mark I
    Mark I Member
    Long Island/Pompano Beach
    It is also likely that you will need to remove the stop for the cockpit door as well as the molding opposite the door.
  5. yotphix
    yotphix New Member
    Southern California
    I hate to state the obvious but you asked only about removing. Most washers and dryers easily come apart into five panels plus a drum and then slip out the smallest passages. I don't know the boat but I did that recently then found a more compact pair that came in without disassembly. When I was taking the old units apart I found pretty clear evidence that they had come in the same way.
  6. jterry
    jterry New Member
    removing a washer & dryer from a 45c viking
    thanks for the advice I used a metal cutting saw and cut them up.
    jterry
