Click for Burger
Click for GPlink
Click for Bertram
Click for DeAngelo
Click for McKinna
Click for Ferretti
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > anti fouling paint for aluminum yacht
Reply
Old 07-15-2010, 07:47 AM   #1 (permalink)
Registered User
good day all.i just want to tap into the centuries of collective experience here.i am running an 80ft aluminum hull sailboat,the bottom needs painting badly.last done in turkey last year with tin based INTER TRILLUX 33.not available anymore,and, i am fairly sure, not allowed in new england where i am now.anyone know any good websites i can educate myself with?i may wait til i get back to florida or bahamas as i think it would be alot less expensive and may offer more options.
thanks in advance.lets hear it.
cw
Chris W is offline   Reply With Quote
Old 07-15-2010, 09:02 AM   #2 (permalink)
Senior Member
K1W1's Avatar
Quote:
Are you sure you have the right description?
International claim it is a Tin Free Anti Fouling:
http://iyp.yachtpaint.com/uk//produc...ePageID=5048#1
Here is it's Certificate of Compliance:
http://iyp.yachtpaint.com/uk/pdf/trilux33_cert.pdf
Have you tried these guys?
http://www.jamestowndistributors.com...uct.do?pid=887
K1W1 is online now   Reply With Quote
Old 07-15-2010, 09:27 AM   #3 (permalink)
Registered User
kiwi,right again
it does say tin replacement,left over can i have is kind of covered.i would like to use the same product so as to make complete sandng not needed.i found out they only did one coat when it was last done.i would do 2 coats and a third around the water line.
thanks.
cw
Old 07-15-2010, 10:52 AM   #4 (permalink)
Senior Member
NYCAP123's Avatar
thanks.
cw
Although I'm not up on the current crop of anti-foulings, let me just say use a paint that is rated for the tropics. Barnacles are going a bit nuts this year up north here. I'm already seeing a bumper crop and they don't usually show up until late August around here, and Florida...Well, that's barbacle heaven.
NYCAP123 is online now   Reply With Quote
Old 07-15-2010, 01:43 PM   #5 (permalink)
Senior Member
Marmot's Avatar
Quote:
Originally Posted by NYCAP123
I'm already seeing a bumper crop and they don't usually show up until late August around here ...
Are the sea temperatures up that much or is there more food for them for some reason?
Marmot is online now   Reply With Quote
Old 07-15-2010, 02:07 PM   #6 (permalink)
Senior Member
NYCAP123's Avatar
Quote:
Temps are up and the water is clean with lots of algae until last week.
Old 07-15-2010, 03:15 PM   #7 (permalink)
Senior Member
As far as I know, TriLux is still available and can be used in the US and is a good paint. Seahawk makes a good product for aluminum as well.
Capt J is offline   Reply With Quote
Old 07-15-2010, 03:46 PM   #8 (permalink)
Senior Member
The boat I'm running currently is aluminum and we used Seahawk. We started in Ft. Lauderdale, then the Bahamas and now PR. Going on a year now and I'm happy with it.
But I'm not happy with their version of Prop Speed though.
Capt Bill11 is offline   Reply With Quote
Old 07-15-2010, 11:58 PM   #9 (permalink)
Senior Member
'RoundTheHorn's Avatar
Something to think about might be Coppercoat. The product info states it is safe for aluminum boats with a proper epoxy primer. http://coppercoat.com/
Quote:
Does Coppercoat cause any problems with regards to electrolytic/galvanic action?
No. With the resin carrier insulating each copper sphere, the final coating is inert and non-conductive. A current can not pass through Coppercoat and this coating does not cause or promote electrolysis or cathodic decay. Consequently Coppercoat can be safely applied to metal structures such as iron keels and steel or aluminium craft (after the application of an appropriate epoxy primer). The property of electrical non-conduction in metallic powders including copper was first discovered in 1890 by Eduard Branley and is known as the “Branley Effect”. Sacrificial anodes should be fitted in the usual manner.
'RoundTheHorn is offline   Reply With Quote
Old 07-16-2010, 01:44 AM   #10 (permalink)
Senior Member
K1W1's Avatar
I have only come across one place where they say Trilux 33 is dis continued.
Here is a place that offers it in a number of different sizes and is in the US.
http://www.boatersland.com/alum.html
Old 07-16-2010, 06:56 AM   #11 (permalink)
Registered User
thanks for the responses
i would be worried about any scratches or damage that breeched the barrier coat when using any copper type paint.i have a very good condition barrier coat intact as the boat is not too old.i would not mind trying sea hawk paint but dont know about compatability with whats left of the trillux paint on the boat now.all this is motivated by my hate of sanding as well.i was told by a shipyard manager in fairhaven that trillux was not available/legal here.maybe they just want to sell me their paint which was 40% more expensive.
i would expect some growth after a year but thick crusty stuff is abit much,i see some other boats going thru the same thing.i do sit alot though without moving.
maybe being in narragansett bay doesnt help with all the runoff lately.
Old 07-16-2010, 02:43 PM   #12 (permalink)
Registered User
My name is Jim Seidel and I am the Assistant Marketing Manager for North America for Interlux. Trilux 33 has not been discontinued. Although Trilux 33 is not available in Canada it is available in the U.S. and in most countries around the world. Trilux 33 does contain a copper derivitive called cuprous thiocyanate as well as a booster biocide of zinc omadine. It does not contain cuprous oxide which is found in most antifouling paint. Paints that contain cuprous oxide are not recommended for aluminum boats without a very thick (20 mils minimum) barrier of epoxy but Trilux 33 can be applied to aluminum as long as normal priming procedures are followed. To find a dealer near you can go to www.yachtpaint.com and click on dealers or contact us and we will help you find a dealer. If you are in North America you can our technical service helpline at at 1-800-468-7589. The helpline is open from 9:00Am to 4:00 PM Monday to Friday.
Jim Seidel is offline   Reply With Quote
Old 07-16-2010, 04:20 PM   #13 (permalink)
Senior Member
K1W1's Avatar
Welcome to YF Jim.
Thank you for the confirmation that Trilux33 is still available and the offer of assistance to the Original Poster.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 06:54 AM.
Click for GPlink
Click for Burger
Click for Horizon
Click for Cheoy Lee
Click for Christensen
Click for Garcia
