Click for DeAngelo
Click for Lurssen
Click for Moonen
Click for JetForums
Click for Cheoy Lee
Click for Bering
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Stabilizer Manufacture Preferance
Reply
Old 06-24-2010, 11:41 AM   #1 (permalink)
Registered User
Which Stabilizer Manufacture is prefered?
cabobo09 is offline   Reply With Quote
Old 06-24-2010, 11:51 AM   #2 (permalink)
Registered User
I am planning on using the Seakeeper System on a 85ft boat that I will be having built
netgain1 is offline   Reply With Quote
Old 06-24-2010, 02:04 PM   #3 (permalink)
m2m
Senior Member
I have had great luck with Naiad stabilizers
m2m is offline   Reply With Quote
Old 06-25-2010, 04:53 PM   #4 (permalink)
Registered User
Can anyone comment on the realibility and maintenance aspects such as seal failure, bearing failure and electronic control systems of the major brands.
Old 06-25-2010, 06:00 PM   #5 (permalink)
Senior Member
Quote:
The only issues I've seen on stabilizers mainly have been hydraulic seal issues, but I'm talking about systems that were made in 1985, and 1988 and both were Naiad. I've also seen cooling pump issues but that's a cheap jabsco or whichever pump.
Capt J is offline   Reply With Quote
Old 06-25-2010, 09:44 PM   #6 (permalink)
Registered User
Swamp fox's Avatar
I run a 72 Marlow with Naiad stabilizers and the only problem I've had is dealing with the fin position sensor mounted at the top of the stabilizer. The sensors go out over time, 5 years or so. Simply change them out. Never had a hydraulic leak or failure, the system seems well built and reliable. I have a dedicated cooling pump for the heat exchanger.
The only downside to stabilizer fins is having something else in the water under your hull to worry about.....
Swamp fox is offline   Reply With Quote
Old 06-25-2010, 10:33 PM   #7 (permalink)
Senior Member
MaxPower's Avatar
i had mitsubishi ARG's on my ferretti 63 ... worked flawlessly ...
MaxPower is offline   Reply With Quote
Old 06-26-2010, 01:55 AM   #8 (permalink)
Senior Member
K1W1's Avatar
Quote:
How many of these units are you going to have to have on your yacht?
I recently reviewed a proposal to fit them to a 36m Sailboat. They would need to fit 5 Seakeeper units on that boat so it is not really an option.
As for Fin Stabilisers, it is hard to beat these guys.
http://www.quantumhydraulic.com/
K1W1 is online now   Reply With Quote
Old 06-26-2010, 09:26 AM   #9 (permalink)
Senior Member
Have you been on a boat that has their MagLift stabilizers on it? If so, do they work well?
Capt Bill11 is offline   Reply With Quote
Old 06-26-2010, 03:27 PM   #10 (permalink)
Registered User
Seakeeper has said that one large unit will control the 85ft that I am planning.
This will provide at least 60% reduction up to 80% reduction in the rock and roll.
Old 06-26-2010, 09:44 PM   #11 (permalink)
Senior Member
'RoundTheHorn's Avatar
Quote:
Here is a report from the then captain of the Inace-built Impetus on his experience with the MagLift stabs. I contacted John DeCaro about a month ago and he stated that Capt. Ben had since moved on. I was hoping for a more recent update on the stabilizers especially any maintenance issues.
http://www.buyexploreryachts.com/new...abilizers.html
'RoundTheHorn is offline   Reply With Quote
Old 06-27-2010, 01:42 AM   #12 (permalink)
Senior Member
K1W1's Avatar
Quote:
I have sent you a PM with some contact details for this guy.
Old 12-10-2010, 05:38 AM   #13 (permalink)
Registered User
ton_meeus's Avatar
There are so many around! It is not only Quantum and Naiad. There is Wesmar, ABT with their TRAC stabilizers, Rodriguez, Roll Royce, Voith, CMC marine (electric stabilizers) and probably others.
For smaller yacht with no hydraulic equipment the new electrically driven stabilizers seem a good alternative. I think the most important part of the stabilizer is the control system. Quantum seems to be the best choice in bigger yachts so my guess would be that their control system is the most sophisticated around.
ton_meeus is offline   Reply With Quote
Old 12-11-2010, 10:16 AM   #14 (permalink)
Senior Member
I have seen a lot of electrical issues with the Trac stabilizers. Mostly sensor issues and such.
I personally like Naiad's.
Old 12-11-2010, 11:57 AM   #15 (permalink)
Senior Member
also hydraulic pump issues as well.
nilo is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 07:56 AM.
Click for Trinity
Click for Walker
Click for Horizon
Click for McConaghy
Click for GPlink
Click for Ferretti
