Click for Abeking Click for Mulder Click for Abeking Click for Furuno Click for Cross
Amizut 39 TV Arial
Discussion in 'Technical Discussion' started by binlidball, Jun 17, 2010.
  1. binlidball
    binlidball New Member
    Bangor
    Does any body know if there is a TV arial connection on the starboard side of the flybridge radar mask, i found a white coaxle cable ? is it for TV are something else? If it is for a TV arial were does the other end finish inside the cabin?
    Your help would be most appreciated :) :)
    That coaxle cable is for hooking up to dockside cable TV. It hooks in near your shorepower and then usually at your power pedistal on the dock (if your marina has cable). Under a similar cover you should find connections for the cable TV hookup and a phone hookup (not that anyone uses phone hookups since cellphones) There should be a TV antenae up top on your radar arch. It's the flatish disc. That should already be hooked into your cable through an A/B switch which you'll probably find in a closet near your salon TV (A=cable/B=antenae or visa versa). Doubt you'll get any TV from the antenae though in your area even before they went digital last year. You'll most likely have to go with dockside cable, DVD's or invest in satelite.
