Click for Burger Click for Cross Click for Comfort Click for Delta Click for Nordhavn
30A to 50A changeover
Discussion in 'Technical Discussion' started by GFC, Mar 13, 2010.
  1. GFC
    GFC Senior Member
    Tri Cities, WA
    My marina was built in 2007 and is only wired for 30A AC power.
    I'm in the process of buying a boat that has 50A service. I'm going to contact the marina before the boat gets here to see if they can/will supply 50A power. To make sure they're giving me correct answers when I ask, I'd like to see what you guys think about it.
    FYI, when the boat is in the slip it will not be running a lot of accessories. I may leave an A/C unit on but other than that there won't be a lot of high power draw things running. When we use the boat we don't sit at the dock. We board up and go.
    My questions are--
    --How much of a problem is it to change the dock power from 30A to 50A?
    --Can they do it for just one slip or would the whole marina have to be rewired?
    --If they will not supply 50A power, can I just buy an adapter to use with my 50A shore power cord to match the 50A fittings on the boat? Marinco makes a 30A-50A adapter that would work.
    Thanks in advance for your help.
    It sounds like you're bigger than their average boat. Yes they can do it for one or two slips or yes you can use a twin 30A female to 50A male Y adapter, but you need to check if they have a 2nd 30A outlet on the pedistal for you to use. The adapter is a bit expensive (almost $500), but every 50A boat should have one on board. Eventually they'll visit a marina with only 30A available.
    Check to see if your boat is 250v (most likely) or 125v (older Carvers come to mind) before you get the adapter or ask the marina to change over.
  3. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Yes the marina can go to a larger gauge wire normally required to increase amperage to 50amp. Also a new pedestal would be required unless they retrofited the exisiting one. Yes you can purchase a couple of different power cords that will work. Your suggestion would work but depending on how the boat is wired might not provide power to what you want. The better suggestion is from NYCAP and go with a double 30a to a 50a especially if you have access to one pedestal that has two 30 amp receptacles on it.
  4. Pascal
    The marina may be able and willing to put 50amp service if you have an annual contract. The easiawst way is to use a smart Y
    as others mentionned it will hook up to TWO 120/30 but they MUST be on opposing phases or the circuitry in the Y will not let any power thru.
  5. GFC
    GFC Senior Member
    Tri Cities, WA
    Thanks for the quick replies. I skimmed over them but haven't really digested the info.
    My pedistal (and all the others) has only one 30A connection and one breaker.
    I doubt they will be willing to spend much money on this changeover even though I do have an annual contract with them. They also know I'm not going anywhere because there isn't another marina around with a slip the size of mine...20'x60'.
    If they refuse to make any changes to their setup, and I OK using an adapter that will plug into the 30A power source and connect it to the 50A cord for the boat? Am I correct in my ASSumption that if I draw too much current through that setup it will only result in a tripped breaker on the pedistal?
  6. GFC
    GFC Senior Member
    Tri Cities, WA
    NYCAP123, yes, it will be the biggest boat in the marina and the only one that can use a 50A service. Since there's only one 30A outlet on each pedistal I won't be able to use the "Y" connector (two 30A's to one 50A).
    The boat is a 1995 Sea Ray so I'm guessing it's going to be a 250V.
    If I ask the marina to install a 2nd 30A outlet on my pedistal, would that and the "Y" adapter provide the solution? Is the second 30A outlet install as simple as just putting in another outlet on the same pedistal, or is there more to it than that?
    This sounds like it's not a simple as adding another 30A outlet. Would they have to run a new 30A wire down to my pedistal to accomplish that? If that's the case, would it be a much larger project to just run a cable large enough to handle the 50A service?
    FALSE, You cannot use a Y adapter and only plug it into 1 30 amp connection. A 50 amp connection is 240 volts, and a 30amp connection is 120volts. So plugging a Y into only 1 30amp connection will only give you power on probably half of your electrical panel (120volt stuff) and nothing 240 volts can work. You need 2-30amp connections to get 1- 50amp connection to work. Maybe you can run a 30 amp cord from another pedestal to where your's is located and plug the Y into the 2-30amp connections. With a Y, you can still pull 50 amps of electricity.
    You may be able to find a step-up transformer to take your single 30amp, and convert it to 240 volts, but you will have limited usage and maybe only 25 amps of power.
  8. NYCAP123
    It sounds like you've outgrown your marina. What any marina would be doing with a 60x20 slip with one 30 amp outlet boggles the mind unless it's a work or transient slip. You can get a 30 to 50 adapter, but that's something you only do for an overnight, in a pinch. You'll kill every 120v or 240v user on your boat.
    With only a single 30 amp outlet at each slip I suspect that their main panel is maxed. Can't seeing such a marina swallowing the expense to upgrade for one boat. Sounds like you've got some sweet talking and/or more likely looking to do.
  9. GFC
    GFC Senior Member
    Tri Cities, WA
    OK, let me try this again because I didn't make myself clear the last time. First of all, going to a different marina is not an option. The one I'm in is the only one that has slips this big.
    My pedistal only has one 30A outlet. My question about using the "Y" adapter was...if the marina could easily install a second 30A outlet then I should be able to use the adapter, right????
    But if a second 30A outlet has to be a different phase from the existing one, is that a huge problem to overcome? Would it require running a second cable just for my pedistal? I doubt they would be up for running a second cable.
    There are no other pedistals that are not being used, so running a second shore power cord from another pedistal is not an option.
    Thanks again for the help....as you can tell, I need it.
  10. Capt J
    Ok, the 2nd 30amp outlet has to be run from a different wire(s) and breaker then the 30amp that is on your pedestal. For example if they have an extra 30amp outlet in the slip next to you that is being un-used, they could in fact use that wiring. What the poster is trying to say, they cannot take one heavy gauge hot wire with a 60amp breaker and wire two 30amp outlets from them and you could then get 220 volts/50amps from it.
    But yes if they could wire a second outlet, you can use a Y. You can also take a 30amp shorepower cord, and hook it to another pedestal down the dock and hook that to one side of your Y and the other side to your pedestal and achieve 220volts 50 amps.
    As for the Searay, it depends on the size and model. Most of the smaller searay's are 120volt 30amp shorecords. I've even run 55' and 56' sedan bridges that were wired for either a 240volt 50 amp cord, but were also wired for a 30amp 120 volt cord (but you could only run 120 volt items from it such as battery charger, refrigerator, water pump, but not items such as a/c's or hot water....W/D.
  11. GFC
    GFC Senior Member
    Tri Cities, WA
    CaptJ, now we're getting somewhere.
    The boat is a 1995 550 Sedan Bridge. I have a build sheet from Sea Ray on that particular boat. It lists the 120V/60cycle appliances on board and also states as an option that was included..."100' Shore Cord on 220V side only"
    It also has two Glendinning Cablemasters so would I be incorrect in assuming the boat has two different power hookups? Possibly a 30A and 50A???
    Here's a picture of the cockpit. It was taken by the brokerage that currently has the boat. It's not the best but it's the best I've got.
    [​IMG]
  12. dennismc
    dennismc Senior Member
    Vancouver BC
    You have to be sure that each 30 breaker in the main panel are on opposite sides of each other, otherwise you will only get 120 V...not 240..would be surprised if all pedastel breakers are on same side of the main panel.
  13. Capt J
    Check the boat in person and see if it has a 30amp plug on the port side of the cockpit next to the other one. If it is not there, it may have one in the garage under those opening hatches on the transom. I am pretty sure the sedan bridges from that era all had 120v 30amp outlets and the breaker panel should also indicate a 120volt 30amp breaker and be set up for it. Keep in mind, you will only be able to operate light items and will have to run the generator for anything wired for 240 volts such as a/c's, water heater, washer dryer, stove.......etc.
  14. GFC
    GFC Senior Member
    Tri Cities, WA
    Thanks to each of you for the information.
    I'm having the surveys done on the boat the first week of April. I'll check the power panel and connections at that time.
  15. NYCAP123
    Just pulled up the specs on that boat and it seems to show (2) x 50 amps. Only time I remember seeing that they were 50/125 which means your situation may be more complicated than you think. When I've run into that in the past both 50's were needed, one for the a/c and the other for everything else. I'd recommend calling the broker Monday to get the facts and then speak with your dockmaster to get his suggestions. Good luck.
  16. Pascal
    It s hard to give you precise advice since we re not sure of what the boat has
    looking at that picture the cable looks small to be 120/240-50, it looks like. 120-50. This would explain why there seem to be 2 inlets on the pic and 2!listed in the listing
    if so, you can plug either one to a 50 to 30 amp adapter. This will give you up to 30 amp service limited and protected by the 30 amp breaker onthe dock
    if you don't gave any 220v appliances (stove compressor or dryer) you van plug the second one into an another outlet without worry about opposing phase
    I do suspect tha 15 years ago sea Ray was still using "small boat" stuff and 120/50 was still popular
    now if this is a 120/240-50 cord you need a smart y which will only activate with both legs hooked up and on opposing phase.
    I use smart Ys once in a while on the 70 I run when stopping at marinas that don't have two 120/240-50 outlets. It works fine although we can't run everything obviously
  17. Mark I
    Mark I Member
    Long Island/Pompano Beach
    IMO you can't go further without knowing what is on the boat now.
    My setup has a single 50 and a single 30. I can use the 30 in a pinch but you have to watch the draw. Block heaters and AC together are a no-no with just 30 amps.
    My previous summer slip had only 30 and it is managable if you are just using AC for dehumidification at the dock.
  18. Capt J
    I have never ever seen searay use 120 volt 50amp shorecords. Remember Searay's are built on the east coast, and the 120volt 50amp is a west coast thing. I have run a 100 different Searays and most of them will have 1 120volt 30amp shorepower cord, even if the boat was wired for a 240volt 50amp cord. I'm willing to bet money that that spare cord is a 120volt 30amp connection.
  19. chesapeake46
    chesapeake46 Senior Member
    I think you should talk to the marina manager before you do much else.
    Besides the fact that we really don’t know what you have for power cords on the boat, you also don’t know what might be available from the marina.
    Even though there is only one 30 amp outlet at the pedestal, the cable FEEDING the pedestal may have enough conductors to make an additional 30 amp 125 volt outlet a pretty easy fix.
    I know that every outlet in our little marina was wired this way and that was done 30 years ago.
    Any electrician that has a little knowledge of boats would most likely take this into consideration.
    As Pascal pointed out, the outlets must be opposing phases to work without a hazard.
    Further, if you are a good customer, ie; buy stuff from the marina, spend money at the marina, they are more likely to install a bigger cable & outlet for you.
    Our marina has done installed 60’s for folks pretty much on demand, especially if the customer is going to stay and pays their bills on time…….
    They may ask you for help on the cost, although our marina does not, they consider it an overall upgrade.
    They also have the capacity to add more load, which is also a factor the marina manager would prolly know.
    Get the real specs on the boat cords.
    Talk to the marina people.
    That’s where to start.
  20. GFC
    GFC Senior Member
    Tri Cities, WA
    I emailed the selling broker yesterday and received this reply:
    "She have the following
    50/125 or 50/240
    She has 2 cable masters for each . You only need to us one to run the entire boat."
    I think to get a definitive answer I'm going to have to talk to the surveyor and wait until the he checks the boat. He's doing that on Tuesday.
