Click for Westport Click for Perko Click for Northern Lights Click for Walker Click for Mag Bay
Three new fuels coming onstream soon; GDiesel, GPetrol and GJet
Discussion in 'Technical Discussion' started by catmando, Mar 1, 2010.
  1. catmando
    catmando Senior Member
    Arlington Tx
    Google clearrefining.com. There is a .pdf article from a diesel magazine on the News section, click on the big pic to read it.
  2. K1W1
    Pretty interesting if it is as portrayed in the glossy promotional materials.
  3. The Reverend
    The Reverend New Member
    La Paz Mexico
    At 48 deg C the flashpoint is a bit low for Marine use :(
  4. catmando
    Arlington Tx
    "Glossy promotional materials" :rolleyes: well if you just so happened to read the magazine article you saw that their test truck's mileage improved at least 3mpg just from GDiesel. That is a serious improvement I can tell you right now.
    If Clear Refining can get Federal approval and the other things they need to start production asap, millions of gallons of dino fuel will be saved in this country. You KIWIs will have to wait, sorry.
  5. Savasa
    Savasa Senior Member
    Iqaluit, Nunavit, Canada
    Greetings,
    Yup it does look good on paper but so does electronic anti-fouling, dripless shaft seals, Algex magnetic fuel conditioning, lifetime oil fiters, the benifits of E-Fuels etc.
    Sorry, put me down as a sceptic and if I'm wrong, I will put an apology in writing.
    Peter.
  6. Henning
    Henning Senior Member
    Ft Lauderdale FL
    I have Cathelco electronic anti fouling on this steel boat (110' Kingship). I don't know whether it is the Jotun bottom paint or the Cathelco, but I just got hauled after sitting 9 months in a spot known for serious fouling and came up clean. YMMV
  7. K1W1
    Where abouts on your boat are the anodes and cathodes installed?
  8. K1W1
    I hadn't seen the PDF till I saw your reply and looked a little deeper which is why I just mentioned the glossy blurb.
    I agree that the Flash Point makes it useless for yachts under current rules and regs.
    The SG of the ULSD is also a lot lighter then a regular ULSD taking it almost half way between regular diesel and ULS Gasoline.
