Click for Westport Click for Northern Lights Click for Mulder Click for Abeking Click for Perko
pay rate
Discussion in 'Technical Discussion' started by pbekker, Feb 21, 2010.
  1. pbekker
    pbekker New Member
    the netherlands
    hello all
    i was wondering what the pay rate (by the hour) is for a service electricion
    in the area of south florida ( miami, key's, ft lauderdale)
    it is just to get a idea (researche)
  2. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Depends, if you are an employee of a contractor, figure $12-25hr depending on skill and experience level, insured contractors bill between $60 & $100. Most yards (especially Lauderdale Marine Center) will require you to submit proof of insurance with them as a named insured before they let you in the gate.
    I own a Yacht Management business in Fort Lauderdale and the 2 seperate marine electricians I use are right around $100 an hour.
  4. pbekker
    pbekker New Member
    the netherlands
    thank you for the answers
    and as a freelancer?
    that is going to the boat onwers for
    repair/ upgrade work on the boats
    like you need for you boat a electrion that fix your plotter or built in a new
    sonar ect
    gr pascal
  5. Henning
    Ft Lauderdale FL
    Electronics installers can be found between $60 and $100 as well, actually, some can be found even cheaper if they are a dealer for the gear being installed because they are making some money there as well.
  6. NYCAP123
    Seems to be a little confusion between electrician and electronics tech. Which are you asking about pbekker?
  7. pbekker
    pbekker New Member
    the netherlands
    hello nycap
    (first of all you can call me pascal )
    but sorry for the confusion
    to make it clear and easy
    the answer will be "both"
    the guy how can instal a gps (hardware + software)
    and who can fix your pumps lights ect
  8. NYCAP123
    Greetings Pascal. I won't comment on pay rate in So. Florida since I'm in NY. You should be aware though that in most places in the U.S. electricians need to be licensed. You also have electricians and master electricians with different pay scales. Also, most ETs charge "travel time" as well as actual time worked because they often travel a bit of distance. The last ET I used had to travel 1 1/2 hours each way (The 2 more local are garbage). Electricians are usually more local and often do not charge travel time.
  9. K1W1
    And dare I add.... be eligible to work in the USA.
  10. Henning
    Ft Lauderdale FL
    Well, depending on the clients requirements, if they're not worried about insurance, licenses (there isn't anybody checking credentials or "code enforcement" on the vast majority of private boats) or immigration status, there are plenty of people to be found in the US who will do any work you please for $10-$25 hr. That's the typical going rate for illegal day workers depending on skill set, and there is no shortage of skilled ones (and extremely unskilled ones as well as outright crooks) in So. Fla.
  11. NYCAP123
    Good point K1W1. If not legal, no insurance, no electricians license, no driver's license, no yards (that I know of) that will let him work on their property. There may be boats that will cheap out and hire illegals to wash & wax, but they'd be crazy to let them mess with their electric or their electronics with no licenses or insurance. That could cost them their boat.
  12. pbekker
    pbekker New Member
    the netherlands
    hey all
    (i need to clear something up i see
    i'm not looking to hire a person bud doing a rescearing what the possiblities are for my self in this area.)
    and under lincens what do i need ABYC or only eletrical school diplomas??
    is it by the way hard to get the jobs (as freelancer)?
    and easy to make/get a good reputation in this area??
    or is it better to look in other states like NY LA ??
    i have +10 years of yachts experians learnt my skills at heesen yachts, moonen shipyard, vitters.(holland)
  13. Marmot
    Anybody care to chime in with information about the license these electricians are supposed to have to work on boats?
  14. NYCAP123
    In NY all electricians must be licensed or work (apprentice) under a master electrician. Is it different in Florida? I know that yards will have their guys doing electrical, but that's different than setting up shop.
  15. m2m
    m2m Senior Member
    newport ri
    nycap are you referring to commercial electricians (ie; household/business) or marine electricians? I am not aware of any state requiring a liscense for an electrician on a boat as long as no work is done on the land side. It is obviously prudent to look into any electricians credentials and background prior to letting them work on your boat.
  16. NYCAP123
    Not sure how much difference there is regarding setting up shop (working for someone else will require a green card). The guys I've used are either the yards or licensed. Either way they were backed by insurance. At least in this area there is no such thing as a "marine electrician" except that service the ships down in NYC, and I suspect that ABYC is not their company's only certification. Never heard of such an animal working the private boats. There are however licensed electricians who are also ABYC certified and promote themselves as marine electricians, but that's not their only work nor the only work they are licensed for.
  17. Marmot
    I believe you will discover that New York State does not license electricians. There is no State electrician's license or State licensing authority.
    Electricians who work on shoreside installations may require local certification.
    There is no such thing as a marine electricians license in the US.
    The USCG has an unlicensed rating for electricians, an engineer's license includes the certification for electrician but requires little if any real training or experience in electrical work.
    ABYC is a voluntary standards organization that has no regulatory standing except when included by reference in USCG standards. ABYC certifies individuals who have passed an examination in ABYC standards. This does not mean they have a great deal of hands on experience, just that they took the ABYC course and know the rule book.
    The FCC requires licensing of those who perform "internal adjustments" of radio transmitters. There is no requirement for a license to install radio equipment, just to adjust, maintain, or certify the installation and that license (the GROL) is easily obtained by anyone with a bit of electronics background. Anyone can legally install modern "plug and play" equipment without holding any form of license.
  18. NYCAP123
    Absolutely right. Electrical licenses are generally at the county level and sometimes the town or city because each has their own codes, but DK any here that don't require it. Again, could be different elsewhere, but I'd be surprised if it were different in Dade or Broward (or maybe not).
  19. Marmot
    We are not talking about house electricians. Don't keep bringing house electricians into the discussion, they are no more relevant to this topic than an auto mechanic or plumber's certification. Terrestrial buildng codes don't apply to the marine world.
    If you don't have knowledge of the industry or the requirements to work on marine electrical and/or electronic systems please just keep silent rather than provide irrelevant and misleading misinformation.
  20. pbekker
    pbekker New Member
    the netherlands
    ok to make it
    clear
    what do i need and how can i get it
    if i like to start in south florida as a freelance service electrician (officale/legal)
    #1 hour rate ex driving time
    #2 rate for driving
    #3 paper work
    background:
    dutch
    +10 years luxe yacht (new build) exprerians (heesen yachts, moonen shipyard,vitters)
    diplomas (dutch electrical) : #1 assant electrician (installer)
    #2 (normal) electrician (installer on your own)
    #3 first electrician (leader over the others)
    greetings
