Quote:
Originally Posted by Marmot And what kind of shift control was used? Was it a Morse cable? What direction did the actuator lever on the gearbox move to select astern?
And who is to say that in the confusion caused by the engine and shaft banging madly around the driver didn't try shifting to see if that would stop whatever was going on?
The position of the gear selector lever is probably the last thing that indicates anything about that incident. |
Morse cables. And the engine falling backward would not pull the cable in such a way as to put the transmission into reverse. In fact it could do the opposite.
"And who is to say that in the confusion caused by the engine and shaft banging madly around the driver didn't try shifting to see if that would stop whatever was going on?"
Don't disagree. But the charterer was adamant that he had never gone into reverse. Only chopped the throttles and gone into neutral.
Again, based on the layout of the controls, I think he "chopped" the gears. :-)
