Click for Westport Click for Glendinning Click for Mulder Click for Mag Bay Click for Burger
Cummins 480 failure
Discussion in 'Technical Discussion' started by Panaracer, Jan 9, 2010.
  1. Panaracer
    Panaracer New Member
    Dana Point, CA
    I have a Sea Ray 2005 390 MY and my Starboard enginee blow a pistol and as a result blow my turbocharger as well. I have 130 hours on the enginees so they are like new but out of warranty. Any idea if Cummings has a history of this problem and might cover the expense, about $10K.
  2. K1W1
    Welcome to Yacht Forums.
    Why did a Piston fail and what sort part of the engine went through the Turbo?
    I would say that lack of use, would have caused the piston issue due to corrossion in the cylinder walls. 130 hours in 5 years is only 25 hours a year or 2 hours a month. Way under what it should be for the engines to be happy or to keep the fuel fresh.
  4. Panaracer
    Dana Point, CA
    It happened at idle and we believe the piston ring wasn't seated with effort pressure at the time of manufacturing(if that makes sense, i'm no expert:
    The mechanic use to work for cummins for 20 years said he hasnt seen this at such low hours. This is my first boat and I only have had it for six weeks. bummer. I don't know if cummins would help me with this unexpected expense. thoughts?
  5. Panaracer
    Dana Point, CA
    Thanks for your reply. Would it make sense to go to Cummins to see if they would help with the repair? Is it likely the Port engine will experience the same thing?
  6. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    Cummins is a very reliable engine, boatdiesel.com has forums specifically on Cummins and the moderator is an expert on Cummins. Suggest to go to the website and read the forums on your specific engine. Good luck! Fred
  7. Panaracer
    Dana Point, CA
    Thanks for your input.
