Click for Northern Lights Click for Ocean Alexander Click for Abeking Click for Burger Click for Westport
Fire Alarm
Discussion in 'Technical Discussion' started by hard hat, Nov 28, 2009.
  1. hard hat
    hard hat New Member
    Veracruz
    Aboard a new Nova Euro 74 at dock 03;30 hrs Carbon monoxide detector in cabin trips low level detection, No engines running AC is on doors and portholes all closed. Next master cabin chimes in. Open and vent rooms search for source and find nothing. Next few days at different marinas and at anchor the same thing happens in the middle of the night. Find no exhaust, stove, fire, wires frying nothing open up vent and back to green. The Owner suspects his deceased Grandfather
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    "The Owner suspects his deceased Grandfather"
    Sounds like a reasonable guess. :)
  3. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    To not upset the other boats, if you drill a little hole either side of the reset button and put a splitpin through, at least you will get some sleep.
    (I never said that) :rolleyes:
  4. hard hat
    hard hat New Member
    Veracruz
    Serious what might be done to resolve this problem, what might really be suspect? Has anyone come across this and found a solution thanks
  5. Fishtigua
    Guernsey/Antigua
    Alarm
    While we are on the subject of alarms/biongs/bleeps/klaxtons.
    Does anyone listen to them???????????
    I'm sorry but everytime I open a car door, do I need a Beep-Beep to tell me I've just opened a car door? I sit in the seat, Bong Bong, yes I know, SHUT UP. Give me 2 seconds to put the belt on.
    After a while all these beeps and flashing lights make us immune to them.
    I used to wake up when pumps went off at night or something sounded 'funny'.
    Having a fridge alarm go off while you're standing in it still baffles me,what do you want me to do? Lock myself in???? Thats just a 2C degree drop, not the Moon plummetting.
    Ok, in the Engineroom a flashing light is needed when you've got ear defenders on but 99% of the time its all B/S.
    What you want is a big RED flashing light and a klaxon shouting "This is going to hurt" at you.
    Then, and only then, do these bloody Beep Beeps make sense.
    Rant over. :(
  6. NYCAP123
    Take a shower and stop breathing. It could also be outgassing from the carpets, veneers, glues, etc.Many of these units just get too darned sensative. Once you confirm that there is no problem hit the reset. If it continues open it up and disconnect the wire. Often if they're disconnected for a while they're ok again. Otherwise replace the unit.
  7. wdrzal
    wdrzal Senior Member
    First, I don't know a thing about your boat or it' detection system. I'm a ME/EE.
    What I can tell you for certainty is CO is a product of INCOMPLETE Combustion.
    usually not enough air (O2)to complete the combustion with a Hydrocarbon. Also Hot smoldering soot can release CO. In the States OSHA limits worker to 50 ppm. You start getting 400 to 600 ppm your going to feel symptoms and need to leave the area. The thing about CO is it accumulates,a source putting off 5 ppm to 20 ppm (a properly adjusted gas stove) is really no threat for 1 hour,but 20 hours of use latter your exposed to 400 ppm.
    Places that burn hydrocarbons are always the fault,(unless you have a leaking bottle of CO on board for calibration reasons.) Engine, gen sets,etc. A yellow flame is a signature of incomplete combustion.............Gas stoves ,ovens are big producer as are propane vented or un-vented Fireplaces. They lower the O2 to get the life like yellow flame look.
    CO analyzers you buy in most store add up the ppm until it's gets to a preset trigger point. You need a CO analyzer(direct reading) & possible a combustion analyzer to track down the source. In the states Bacharach inc. make some of the best. You can even have them provide a NIST traceable certificate in you want. I'm pretty certian different yachting societies will have different standards
    In the states ASME (American society ofMechanical engineers),or a member of ASHRAE (American society of heating,refrigeration & air conditioning), or even RSES (Refrigeration service engineers society) should have the proper tools & knowledge to track down your CO problem .
    Of course take this serious from the start,if it's a false alarm,let the experts prove it. It's very possible you just grill to many Steaks without proper ventilation.
  8. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    Do you have a fresh air make up system that sucks in air from out side? That might also be sucking in exhaust from a gen next door? Or even yours at anchor?
  9. K1W1
    Fish,
    It is obvious you are not an natural engineer- You should always push the reset button in first and use the split pin to hold it in or it will not be able to be reset with a split pin all the way through it - Will it.
  10. Garry Hartshorn
    Garry Hartshorn Senior Member
    I find a toothpick or matchstick often works quite well. Sometimes followed by the float test. :eek:
  11. hard hat
    hard hat New Member
    Veracruz
    I will let you all know what is found to be responsible for triggering the alarm. remember it's not one but two different rooms. And at different Marinas and anchorages. The detectors do reset to green once the room is ventilated, there is no gas or flame or elec stove in use. On a couple of nights not even the light plant is running.
  12. Pascal
    low battery voltage? that will trigger a DC CO detector.
    last week, the main battery charger (only a few months old) got a little warm due to a hot engine room and started cutting off. With every thing on, it only took a few hours for battery voltage to start dropping. It never got low enough to trigger the CO det. but low enough for me to start looking into the problem. and solving it by putting a fan on the charger.
    so who knows, besides outgasing (if new boat) an intermittent charger could cause voltage to drop low enough.
