| |  | Head tank discharge pump and operational details |  | |
10-26-2009, 09:55 PM
#1 | | Registered User
2002 Tiara 4000 Express.
The Tiara manual states it is not equipped to discharge sewage overboard (when off-shore of course). However there IS a diaphragm pump in the compartment beneath the trunk and it looks like a head tank discharge pump to me. There is no switch for that pump (that I can find).
I need some of the coastal saltwater folks to enlighten me. Is that pump for discharging the head tank? Where are the controls? Any idea what it would take to connect it?
10-26-2009, 10:26 PM
#2 | | Senior Member
What on earth is a trunk on a yacht? It might very well be a macerator pump to pump sewage overboard. It probably was dealer installed. It might just run off of a macerator breaker on the breaker panel.
10-26-2009, 11:07 PM
#3 | | Senior Member
Join Date: Feb 2006 Location: Sarasota/Ft. Lauderdale FL
Do you have VacuFlush heads? It could be the vacuum pump for them/it?
10-27-2009, 06:49 AM
#4 | | Registered User
| Quote: | Originally Posted by Capt J What on earth is a trunk on a yacht? It might very well be a macerator pump to pump sewage overboard. It probably was dealer installed. It might just run off of a macerator breaker on the breaker panel. |
Tiara owners will know what the trunk is. It is an aft storage compartment, that opens out onto the swim platform. Inside the trunk is a hatch to a systems space below waterline, hard up to the transom.
I'll clarify my o.p., there is no circuit breaker on the main AC/DC panel, no breaker on the engine room DC panel. There is no switch to operate the pump.
10-27-2009, 06:50 AM
#5 | | Registered User
| Quote: | Originally Posted by Capt. Bill11 Do you have VacuFlush heads? It could be the vacuum pump for them/it? |
Yes, the vessel has Vacuflush heads. The vacuum pump is also a diaphragm pump but is beneath the sole near the galley.
10-27-2009, 08:57 AM
#6 | | Registered User
Are there hoses connected to this pump? If yes trace them out one should go to the holding tank and the other to an overboard valve. Having determined that this is the case I would trace the wires back to their origin. If they are not connected to anything you could wire to the panel to an unused breaker, or add a new breaker. Is the pump a Sealand pump and does it say T-Pump on the label, if so it is a transfer pump.
10-27-2009, 08:59 AM
#7 | | Senior Member
| Quote: | Originally Posted by whiskywizard Tiara owners will know what the trunk is. It is an aft storage compartment, that opens out onto the swim platform. Inside the trunk is a hatch to a systems space below waterline, hard up to the transom.
You might find that there is a slightly more nautical term for what you call the Trunk. http://en.wikipedia.org/wiki/Lazarette
I second m2m's suggestion to see if the pump is actually connected and if so to trace the plumbing and cables.
__________________
Cheers,
K1W1
10-27-2009, 12:40 PM
#8 | | Senior Member
"It is typically found below the weather deck"
Ah, but there's the rub, his "trunk" is not below a weather deck. :-)
10-27-2009, 01:33 PM
#9 | | Senior Member
Is there some reason a dealer can't help?
10-27-2009, 01:45 PM
#10 | | Senior Member
| Quote: | Originally Posted by Capt. Bill11 "It is typically found below the weather deck"
Ah, but there's the rub, his "trunk" is not below a weather deck. :-) |
What is considered the weather deck on one of these point and squirts?
__________________
Cheers,
K1W1
#11 | | Senior Member
| Quote: | Originally Posted by Marmot Is there some reason a dealer can't help? |
Yes, No one has asked one :-)
__________________
Cheers,
K1W1
10-27-2009, 06:20 PM
#12 | | Registered User
| Quote: | Originally Posted by K1W1 Hi,
I second m2m's suggestion to see if the pump is actually connected and if so to trace the plumbing and cables. |
I might, but lazarette isn't it. Tiara calls it both a trunk and a garage, interchangeably.
I assure you that if it were easily traceable I would have done so. Thanks for the help.
10-28-2009, 04:05 AM
#13 | | Senior Member
| Quote: | Originally Posted by whiskywizard I might, but lazarette isn't it. Tiara calls it both a trunk and a garage, interchangeably. |
Given the pictures of one of these boats shown online I would call it a garage or lazarette myself, as the dealer isn't consistent with their name for it I have to ask myself if this is an indication of other non nautical practices on one of these.
I don't think anyone wrote that it would necessarily be easy to trace the plumbing and wiring of this pump even if you are able to look at it and get your hands on it.
Given this can you imagine how hard it is to trace/identify/diagnose by others who are not able to have the benefit of such a close encounter?
As posted earlier- Have you asked a Tiara Dealer for some assistance with this?
__________________
Cheers,
K1W1
10-28-2009, 04:28 PM
#14 | | Senior Member
What is considered the weather deck on one of these point and squirts? |
Good question.
Which I can't answer. :-)
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 07:54 AM. | |
