Click for Westport Click for Nordhavn Click for Ocean Alexander Click for Abeking Click for Burger
24v Battery Boat System - need 12v
Discussion in 'Technical Discussion' started by CSkipR, Oct 5, 2009.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    My boat has 6 batteries. Two are for the engines and wired in series at 24volts. The other four are for the generator/house wired in series at 24v. I ran #6 wire from the flybridge to the battery compartment in the engine room to power a stereo amplifier but I am not sure if I can wire directly to one of the batteries for 12v power since they are wired in series. Also my battery charger is a PT24-40 Newmar and charges at 24v. Any assistance is appreciated.
  2. K1W1
    You should be able to get 6,12,18 and 24V out of a combnation of 4 6V Batteries.
    If you start at the positive of the set and follow the lead from the negative terminal of the same battery you will see it goes to the positive of another one.
    If you use your test meter between the first positive and the negative of the second battery you should see 12 V.
    You can also do this in reverse starting at the negative post.
    I am not sure taking a constant draw off one battery ( or 2 in your case) connected in series is a good idea from what I have heard but have not personally experienced any failures that I would attribute to this practice.
  3. CSkipR
    CSkipR Member
    K1W1
    All the batteries are 12v Odysses AGM. Are you saying just tap on one battery even if it is hooked in series. What about the 24v battery charger will it create a problem.
  4. Pascal
    it's not ideal since some of the batteries will work harder than the other ones and those that are not used for the amplifier maybe a little overcharged... but it will work
    If the amp. pulls a lot and/or is used a lot, you're much better off doing it right which is hooking it up to a 24 to 12v converter
    I second this. An Amplifyer uses a lot of electricity and If you connect to 1 battery out of a 2 battery bank, the charger is going to charge both batteries in that bank and end up frying one of them. Ideally for a stereo amp, you're going to want a dedicated battery for it, which you could install on the flybridge and then you are going to need a battery charger for it. But that will give you the least amount of interference.
    An amplifyer spikes amp draw too much to use a converter and will cause a lot of line noise in the speakers from what I have seen.
    It may be ok to hook the AMP to 24 volts, read the specs on it, but a lot of electronics can handle say 8-30 volts but not all.
  6. K1W1
    The fact that you have four 12V in Series means that there must be two pairs in parallel or you would have 48V at the end of the connections.
    When I read you had four batteries I just assumed that they must be 6V Cells as four in series for 24V is not something I have come across before.
  7. captain_jack
    captain_jack New Member
    Seattle
    You can't tap one 12 volt battery that is being charged in series with a 24V charger, as mentioned, one battery will be cooked as the regulator tries to charge the dead one.
    Best and cheapest solution is to pull a second piece of #6 to the second 12 volt battery wired in series with the first one.
    As long as the load is split equally between the two batteries in series there will be no problems.
    Parallel the two #6's at the amp with a distribution block, you cant have too much current for an amp, so this should work well. Verify all your voltages before connecting equipment, 24 VDC will fry an amp.
  8. Garry Hartshorn
    Garry Hartshorn Senior Member
    Newmar make a DC to DC converter, that would be the best option though others have been mentioned that would work.
  9. K1W1
    If he just runs a single cable between two positives and then picks up the negative somewhere else connected to the 24V System he will have 24V on one of the leads.
    If you are going to do this run a lead from each positive of two 12V Batteries connected in series and another lead from each negative on the same batteries.
    As suggested above join both pairs of the like polarity leads near the amp in a JB or similar and please test the result before connecting your equipment via a fuse protected link to the supply.
  10. Garry Hartshorn
    As I understand what you have and would like to do what I have drawn will work. The positive post on batteries #1 & #3 will have 24VDC at all times not only from the charger but because the batteries are in series. Batteries #2 & #4 will have 12VDC at the post, however it is problematic due to the uneven loads placed on the batteries. You will end up replacing batteries more often !! The best solution is a 24VDC to 12VDC converter.
  11. K1W1
    When I went to school I do not recall being able to get 24V out of two positives without the addition of a negative somewhere. ( normally connecting one positive to one negative)
    Where would you have this guy hook his negative to this solution?
  12. Henning
    Henning Senior Member
    Ft Lauderdale FL
    To the negative buss. It's pretty simple really.
  13. Garry Hartshorn
    Thanks Henning, I should have mentioned that.
  14. Henning
    Ft Lauderdale FL
    :confused: :confused: It was on the schematic..... which is pretty much how I set up all my house banks, one series buss and one parallel buss. The negative buss works both. Several of the better inverters do it all for you as well.
  15. CSkipR
    CSkipR Member
    24v to 12v
    Garry,
    That is very similar to what it looks like. I'm not at the boat and unfortunately don't have a picture in front of me. Not sure about a converter will it handle the amperage of an amplifier. Typically what do these converters run. After running the two # 6 wires it seems like a waster to have to purchase a converter when I have 4 new house batteries.
  16. Garry Hartshorn
    That would be your choice, both will work, a converter would be more technically correct. As to the selection of the converter you would have to check out the spec's, I understand that Newmar have quite a range and I am sure there are other manufactures out there as well.
  17. Capt J
    If I remember correctly, you have a 43' Cabo. I believe CABO installs a 12 volt battery buss from the factory, on the expresses it's on the foward bulkhead under the clear plexiglass for hooking up electronics to and so on. I cannot remember if the batteries are on the starboard rear of the engine room like the 48's, or foward center like the expresses. Test for voltage.
  18. CSkipR
    CSkipR Member
    Capt J,
    You are correct its a 43 Cabo FB. There is one buss bar visible with plexiglass over it mounted on the starboard rear side of eng room. I have never checked the voltage at those lugs. The batteries are located on this side too.
    There is a negative grounding bar with a number of yellow wires connected in front of battery box.
    Your thoughts are appreciated.
  19. Capt J
    I might be wrong, as it's been a while since I've worked on a 43'. BUT, I think those are 12 volt buss bars installed by Cabo for the sole purpose of having them there for 12 volt electronics and such. Check the voltage on them, but I think you will find your 12 volt there. and you would use the negative buss bar located there with the yellow wires I believe.
  20. Henning
    Ft Lauderdale FL
    Unless you are looking to run an amp for a major rock concert, you will have no problems just hooking up to a positive and negative terminal off of one of your batteries. I'm assuming you're hooking up a car stereo amp, and unless you're looking at bass booms to shatter the windows, you won't be drawing enough current to cause any problems with your charging system or batteries. If you were running a bow thruster or 12v refrigeration, that would be an issue. A stereo amp or some bridge electronics, cell phone charger....no worries.
