Click for Burger Click for Cross Click for Nordhavn Click for Glendinning Click for YF Listing Service
Fuel gauges
Discussion in 'Technical Discussion' started by libertyac, Oct 2, 2009.
  1. libertyac
    libertyac New Member
    Freeport Bahamas
    This 82 Broward has Trans-America deLaval gauges which are out of order and I wonder if anyone has any experience of them or any source of technical help.
    A search of the internet has proved fruitless so far and it seems the company was swallowed up by some other outfit some time ago
    The alternative is replacing them and hopefully being able to match the sensors to new gauges . If anyone has any ideas, I would be most grateful.
  2. Hot Rod
    Hot Rod New Member
    Blue Water Point Marina, Oak Island, NC
    Fuel Guage
    Do you know if the sender employs the standard 240-33 Ohm or the Moeller 240-35 calibation? TeleflexMorse marine sender kit and gauge is what I have used in a 400 gallon tank. The sender can be adjusted for different tank depths. This sender is designed for the standard 5 hole screw pattern. The gauge hole is 2 1/16 hole diameter. Hope this is helpful.
  3. K1W1
    They seems to have been swallowed by Gems Sensors Manufacturer, I found this addy: Transamerica Delaval Inc., Cowles. Rd., Plainville, CT 06062
  4. libertyac
    Freeport Bahamas
    Thanks Kiwi and Hot Rod for that info.
    Am back in RSA for a few weeks and very happily Boat-less but will check it out in Jan.
    Happy Holidays
    Pete
