Click for Oceanco
Click for Christensen
Click for Queenship
Click For Dockwise
Click for Platinum
Click for Moonen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Descaler in Fort Lauderdale
Reply
Old 07-30-2009, 01:29 PM   #1
RBJacobson
Registered User
Does anyone know an engine descaler company in Fort Lauderdale other than Trac?
RBJacobson is offline   Reply With Quote
Old 07-30-2009, 03:02 PM   #2
K1W1
Senior Member
K1W1's Avatar
What is your experiences with TRAC? I have seen them at a few of the shows and often wonderdd if it was as good as it says on the tin.
You can PM me your TRAC experiences if you would like to keep it private.
It is not hard to descale the cooling system in your engine yourself and once you have the equipment setup it is a relatively cheap job.
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 07-30-2009, 04:13 PM   #3
RBJacobson
Registered User
Trac does a good job and the barnacle buster stuff they use works great, it is just that they can't get to the boat for a bit and I was wondering if there was someone else. I remember there was a float up service that did it but could not track them down.
I know it is not a difficult job, just don't want to buy the equipment and supplies.
Old 07-31-2009, 08:37 AM   #4
Ken Bracewell
Senior Member
Ken Bracewell's Avatar
Great product.
All it takes is a pump and a garbage can, so we flush our own systems.
__________________
Never trust a captain who enjoys swimming!
Ken Bracewell is offline   Reply With Quote
Old 07-31-2009, 10:18 AM   #5
C4ENG
Senior Member
C4ENG's Avatar
My Expereince with Trac has been it only works on removing calcium build up. Unfortunately I have seen more of a vegetation-slime-mud growth build up causing me issues in cooling systems and the ER and Trac does not dissolve that. More than once I have experienced such.
Hard core, eat your pipes from the inside out acid descalers are the only thing I have seen that works for everything..
C4ENG is offline   Reply With Quote
Old 07-31-2009, 10:46 AM   #6
K1W1
Senior Member
K1W1's Avatar
Quote:
Originally Posted by C4ENG
Hard core, eat your pipes from the inside out acid descalers.....
Get better quality pipes then, I have previously used Phosphoric Acid with great success on a lot of different systems with some of the best results being Jets Pumps- Cleans them up like new without having to remove the front cover :-).
__________________
Cheers,
K1W1
Old 07-31-2009, 10:47 PM   #7
Capt J
Senior Member
Refit Management Service- descales engines, does a good job and has reasonable prices 954-257-1732
Capt J is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 04:57 PM.
Click for Moonen
Click for Westport
Click for Dyna
Click for Crescent
Click for Cheoy Lee
Click for MCC
